Quick question about wheel and tire size
Old Jun 18, 2006 | 08:46 PM
MrBig's Avatar
It works on my machine
I tried searching but could not come up with anything. Can you mount a 245/40-18 on a 18x8 wheel?
Old Jun 18, 2006 | 08:51 PM
GLuXuRy's Avatar
whats stock 225/45?
Old Jun 18, 2006 | 08:58 PM
MrBig's Avatar
235/45-18, I'm really bad at this wheel tire thing.
Old Jun 18, 2006 | 08:59 PM
GLuXuRy's Avatar
hmm... 10 more MM... it might fit... hold up im gonna try searching this... im sure someone either has this or has done it
Old Jun 18, 2006 | 09:50 PM
kenchan's Avatar
i think you can mount it, but here's the factory sizes for 18's:
225/45/18 front
245/45/18 rear
i would do this if i was going to swapout the tires:
225/45/18 front (add 15mm offset spacer)
255/45/18 rear (add 5mm offset spacer)
Old Jun 18, 2006 | 09:51 PM
g35doc's Avatar
yes it'll fit
Old Jun 19, 2006 | 12:04 PM
darnelled's Avatar
Most of them will fit with no issues, but look up the specs of the specific tires you want at www.tirerack.com
see http://www.tirerack.com/tires/tirete...p#measrimwidth
to interpret the specs
Old Jun 19, 2006 | 01:33 PM
codeflux's Avatar
MrBig it would help if you specified if you have SEDAN or COUPE!
245/40-18 should fit on 18x8. it fits perfectly on 18x8.5, and an extra half an inch should not make that much of a difference.
Old Jun 19, 2006 | 08:22 PM
MrBig's Avatar
Your right! Sorry I usually post in the Sedan thread. The reason I want 18x8 is because I found a set of wheels that I really like, and they only come 8" for the 18" wheel. I want to stay 18" because I do autoX and I want less wheel mass spinning. Thanks for the help.
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
Detailed Image
Jul 24, 2015 12:31 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
