Shaving wheels to clear calipers
Old 08-24-2006, 10:01 PM
geeitup's Avatar
Anybody ever try to mill or "turn" wheels to take material off the inside of the spokes. Just attempted to install a Stoptech BBK and have approx. .5mm clearance which isn't enough. I'd prefer not to run a spacer since my 35mm offset wheels are at my personal limit already. I did print out the template and it appeared I had about 2mm clearance, but I guess not. I'd just have to take 2mm off the ridges (extra material cast on the inside edges of the spokes) on the inside of the spokes. I know these ridges provide strength for the wheel, but 2 mm would still leave approx. 3 mm of the ridge remaining. I do track my car so I'm am concerned over high stresses, but you have to figure wheels have a design safety factor of about 2. Inputs?
Old 08-24-2006, 10:20 PM
absolutg's Avatar
workin...
so you want to take away 40% of the ridge? i don't think there's that much safety cushion built in... what size bbk did you get? 13"?
Old 08-24-2006, 10:31 PM
STill_matic's Avatar
I've never heard of anyone wanting to shave the wheels.. only the caliper.
Old 08-24-2006, 10:43 PM
Andy2434's Avatar
Danger, Will Robinson! . . . Danger, Will Robinson!
Old 08-24-2006, 10:45 PM
abcquackyxyz's Avatar
Shaving the rims is way to dangerous. Looses its structual strength...Risky...Get new rims?
Old 08-24-2006, 11:34 PM
obender66's Avatar
Shave the caliper. I do not think you will compromise strenght by taking 2 mm off, but what about balance?
Old 08-25-2006, 12:28 AM
TwoK4drSi's Avatar
run a 5 mm spacer. you don't even need to replace the studs.
Old 08-25-2006, 08:39 AM
SilverII's Avatar
get new wheels!
Old 08-25-2006, 02:36 PM
codeflux's Avatar
get new wheels. you do realize that the wheels is the one thing that's preventing you from hitting other cars and stuff, right? if you have no wheels (as in, they break off), your brakes won't be too effective.
Old 08-25-2006, 02:55 PM
Jeff92se's Avatar
Red Card Crew
I really doubt a wheel maker would design their wheel on that ragged of an edge where a mm would make a big diff. But you would be hardpressed to find someone to actually recommend it.
Another idea is to take 1 mm off the caliper and 1mm off the spoke.
Or as someone else suggested a spacer. I'd take a commonly available 5 mm spacer and have a machine shop mill it down to 2-3mm. That's probably what I'd do
Old 08-25-2006, 05:39 PM
g35rcr's Avatar
Just get spacers and longer studs, that way we dont have to read your next post..."shaved my wheels to save money now I don't have a car and people are calling me names"
Old 08-25-2006, 08:22 PM
geeitup's Avatar
Thanks for re-enforcing what I think I already knew. Shaving 1mm off the wheel and 1mm off the corners of the caliper would be ideal but a pain. I'm not even sure I could find someone to do the wheels and if I did shave the calipers, I'd have to re-paint them. Getting a 2mm spacer (or milling a 5mm down) is the most logical and I'll just have to get used to the wheels sticking out farther.
Old 08-26-2006, 01:35 PM
_jb's Avatar
_jb
_jb is offline
Photographer
Don't shave the wheel!
If the wheel ever did break, for any reason, you would be totally liable. No insurance company would cover an accident where a wheel broke and the owner ground material off the spokes.
Sell your wheels and buy new wheels that fit.
Old 08-26-2006, 01:52 PM
Andy2434's Avatar
+1 A very excellent point.
Old 08-26-2006, 02:26 PM
1illgt350's Avatar
buy new wheels... even used ones off the forum if money is an issue.. just somehting to run around with till you sace enough dough for the rims you really want.. ive seen oem 18 go for really cheap.. good luck and dont damage the integrity of the rims by shaving off parts of the spokes
Quick Reply: Shaving wheels to clear calipers
