need your help on tire and rim sizes..
Old Sep 29, 2006 | 01:06 PM
SeOuLG35's Avatar
I tried to seach it..but either it didn't give me anything
or was just giving me 100000 different threads..
anyways,,
I'm trying to get new shoes for my 06 DG coupe..
just wondering what are my options as far as sizes..
I'm trying to go with either 19 or 20s..(I currently have stock 19)
and I wanna have a wide rear tire..
-please let me know the sizes that will go fine and not
affect the performance..
-and whether I'll have to roll my fender or not..
-and if I go off set/how much..what will be the difference?
haven't fully understand the concept of being off set...sorry
I'll also appreciate if you can give me any links to this matter..
thanks
Old Sep 29, 2006 | 01:26 PM
Calvin's Avatar
Overglorified Altima
gets 19s. IMO 20s are over the top for the g
im getting 9.5/10.5 with 255/35 and 275/35
i could have gotten 285/35 in the rear (i would definitely rub) so i would have to shave my fenders
as for offsets, what ive understood is the lower the offset the more aggressive it will look. ive seen +17/+18 offsets and they were amazing. im getting +23 all around and am very happy with that.
do you have any particular wheels in mind? that would help..
Old Sep 29, 2006 | 02:17 PM
SeOuLG35's Avatar
so the greater the number of off set..
the more aggressive it looks..right?
does that mean that it will be wider?
and..I was thinking of Volks GT-S or SF Challenge
Old Sep 29, 2006 | 02:20 PM
SeOuLG35's Avatar
^thanks BTW
Old Sep 29, 2006 | 03:07 PM
Calvin's Avatar
offsets in the 30s are weak. lower 20s..good
in the teens..great (IMO)
Old Sep 29, 2006 | 03:30 PM
SeOuLG35's Avatar
oh I see...
thanks..
Old Sep 29, 2006 | 05:09 PM
G35Bearcat's Avatar
Basically offset is the distance between the hub mounting face and the wheel centerline. For a picture and a more detailed description follow the link below.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
The amount of offset does not have to affect the look of the wheel, but many wheel manufacturers do change the look of the wheel to obtain the desired offset. Offset is important to vehicle handling. Typically, to have the least affect on handling when changing rim widths, you would make sure that the track width (distance between the center of the left and right rim) remains the same and calculate the needed offset from that and the distance between the left and right hubs. This is probably way more of an explanation than you wanted, but I hope it helps.
Old Sep 30, 2006 | 02:38 AM
optimystic06's Avatar
Only certain rims can get away with having such low offsets. Most rims won't clear the caliper w/ such low offsets. (below 20)
Old Sep 30, 2006 | 03:21 AM
Calvin's Avatar
this is true
ive seen +17 and +18 on some volks for the g (forgot which ones) and they were siiiick
Old Oct 2, 2006 | 05:08 PM
SeOuLG35's Avatar
thanks for the info..
and for the link
Old Oct 2, 2006 | 06:51 PM
venommaxr33's Avatar
Must Go Faster!!
These are the wheels im looking at getting. Discount tire is gonna match the price so i can get their warranty on the tires!!!!(that has saved me many times in the past. What is the best offset i can get to clear the brembo package?http://www.wheelsnext.com/default.cf...or=HYPERSILVER
Old Oct 4, 2006 | 05:40 PM
SeOuLG35's Avatar
nice choice
let us know how it looks once you put them on
Old Oct 6, 2006 | 01:35 AM
USANSealKYoon's Avatar
Stealth
the 17" and 18" combo must have been the famous volk gts(challege look alike)
also lower the offset bigger the lip. lipsize also depends on wheel construction. there are some with 25 offset with no lip i think it's the progessivME(volk)
i have 275 on my g with a 10.5 width. i could put some 295 on there to get a non stetched look(pilot sports) and not rub. and my car is not lowered
Old Nov 30, 2006 | 04:43 PM
bjdraw's Avatar
kevinrt8700m5:
What offset are you running?
I would like to run 19x10.5 with 295, the offset the shop here has in stock is a +18 and they stick out way to far.
I am more interested in a non-stretched look and a wide tire than a wide lip.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Jussumman
Dec 22, 2015 10:23 AM
Fire0nic3
Aug 31, 2015 03:18 PM
BlackGee35
Jul 31, 2015 11:04 AM
