Wheel width issue
Old Nov 24, 2006 | 03:13 PM
grifter91's Avatar
Wheel width issue
Its hard to find wheels that are in the 8" Front / 8.5" Rear setup. If I am forced to use 8.5" all around or 8" Front / 9" Rear, is that a problem? Obviously, I would need to stagger the tire width to satisfy this, but will the wheel width be a serious problem?
Old Nov 26, 2006 | 07:19 PM
Eagle1's Avatar
It is not necessarily a problem at all. I am running 9.5"front and 10.5" rears on my track set up, with 275F and 315R treadwidths for the tires.
However a key element will be the offsets that the wheels have, so that you do not wind up rubbing the inside of the tires on the suspension, or the outside on the fender wells. Use a wheel sizing program at a place like TireRack to help you out with the selection. to the extent possible, try to use a combination that maintains the same wheel and tire overall diameter/circumference of your stock set up, so as to not impair accuracy of your speedometer/odometer and your vdc.
Old Nov 26, 2006 | 08:42 PM
kenchan's Avatar
^^ holly ****... 275 up front, huh? dang...!
Old Nov 30, 2006 | 10:36 AM
bjdraw's Avatar
Eagle1 what offset are you running?
Any problems rubbing on the inside of the wheel well? Assuming you have a g35 coupe.
rezendvous420
May 31, 2020 01:26 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Popes
Jul 29, 2015 05:07 PM
itschuckster
Jul 25, 2015 08:07 AM
