Difference Between pilot sport and PS2's
Old Feb 6, 2007 | 11:52 PM
srmfball's Avatar
Hi, could someone tell me what the difference is between the Michelin Pilot sport tires and the Michelin Pilot Sport 2 tires.
Old Feb 6, 2007 | 11:58 PM
iLLG35's Avatar
NY G-Squad G Race Driver
Pilot Sport 1's are pretty much obsolete to the 2's. PS2's have a different tread pattern with the outside shoulder being a softer compound as well (very basic info but the PS2's have better dry and wet performance), they have AMAZING grip. I have PS1's on my GT2 and they arent too good , but it also depends on your usage!
If you dont have a high hp/tq car, it really shouldnt matter, PS1's are still good!
Old Feb 7, 2007 | 12:00 AM
srmfball's Avatar
I have ps1's on there right now. I need to change the rears. Would it be bad to mix and match?
Old Feb 7, 2007 | 12:09 AM
iLLG35's Avatar
Yes!!! Check out the info of the PS2's on tirerack, they are pricey. I would just get some new rears for your car in all honesty!
Old Feb 7, 2007 | 12:12 AM
srmfball's Avatar
I have ps1's on all 4 wheels right now. I wanted to keep the ps1's in the front and put ps2's on the rears. Is that bad to do?
Old Feb 7, 2007 | 12:23 AM
slikmo22's Avatar
I just bought a set of ps2's but didnt put them on yet...ill keep you posted
Old Feb 7, 2007 | 12:26 AM
srmfball's Avatar
how much did you pay?
Old Feb 7, 2007 | 12:31 AM
slikmo22's Avatar
nvm i have the pilot sport a/s's heres the link on tirerack http://www.tirerack.com/tires/tires....ot+Sport+A%2FS
Old Feb 7, 2007 | 09:32 PM
srmfball's Avatar
bump
Old Feb 7, 2007 | 09:48 PM
JZ39's Avatar
The sidewall of the PS1 is too soft. I couldn't believe how flimsy the sidewall was of the OEM 245/18s. Def. leads to a lot of body roll in corners.
I can't speak to how stiff 245/18 PS2s are, but the 225/18 PS2s that I felt were very stiff. I think the PS1s are more of a compromise for those wanting some sport with some luxury, hence why they were chosen as an OEM tire for a sports/luxury coupe.
Old Feb 7, 2007 | 10:04 PM
srmfball's Avatar
Would it be bad to have ps1's on the fronts and ps2's on the rears?
Old Feb 7, 2007 | 10:37 PM
Chrlesmd's Avatar
Ideally you shouldn't run 2 different sets of tires. The ride will handle a little weird, esp if the 2 sets have different characteristics. But if you had too, I would definately put the ps2s on the rear. They're a good all around tire. Had them on my Maxima.
Old Feb 11, 2007 | 12:28 AM
Trezi13's Avatar
does michelin make the ps2's for the oem offset 19's??
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
bjo16
Aug 4, 2015 09:52 AM
