Rear Tire Feathering Possible?
Old Apr 5, 2007 | 12:50 PM
samualcc's Avatar
All,
Does anyone know if it is possible to have rear tire feathering? I have only 7000 miles on my summer rears and they are wearing heavily on the inside tread on both rear tires. I know front feathering is semi common, but I could not find any specific references to rear tire feathering.
Old Apr 5, 2007 | 12:58 PM
izmir41500's Avatar
G35driver Addict
yes it is possible. when's the last time you got an alignment?
Old Apr 5, 2007 | 01:17 PM
BadBoy06's Avatar
^^^ as he said..need to get it looked at. more then
likely>>too much negative camber
Old Apr 5, 2007 | 04:18 PM
terrycs's Avatar
Feathering usually means toe adjustment is out of spec.
Excessive wear on inside tread usually means camber is out of spec.
and, of course you can have a combination of the two.
Old Apr 5, 2007 | 06:03 PM
bocatrip's Avatar
I've heard of inside wear on rear coupe tires. Again there is no camber adjustment for the rears so only toe can be adjusted. It has not been as common a problem as the front feathering issues.
Old Apr 5, 2007 | 06:53 PM
Q45tech's Avatar
Because the rear doesn't have a high caster or any caster.
Don't confuse heel toe feathering with block side to side feathering from toe squirm.
Old Apr 6, 2007 | 01:38 PM
samualcc's Avatar
So if I take it in for an alignment, they should find it out of spec? I have the OEM 19s. Is it possible to have the car aligned, then dismount the tires from the wheels and have them "rotated"? I do not think the Potenzas are directional. Any thoughts?
Old Apr 6, 2007 | 04:31 PM
terrycs's Avatar
Sure, once the suspension is aligned, the tires and wheels can be moved around.
Old Apr 6, 2007 | 05:18 PM
Petoria's Avatar
not to jack the thread, but for some reason, i have outer wear in the rear!?!?! i have 350 htechs installed and it looked like i had negative camber but i got an alignment about a month ago two weeks after i installed the springs
anyone got ideas?
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
wuppiedog
Aug 7, 2015 11:16 AM
socalg35x
Aug 7, 2015 09:36 AM
TheefrshstVQ
Jul 26, 2015 09:37 PM
nascarbuff17
Jul 16, 2015 10:23 AM
