My final Works VS-XX for Sedan thread -offset help needed please
Old Jul 8, 2007 | 01:20 PM
  #91
clinthammer's Avatar
I ordered the O pad unfortunately for the fronts and rears. Rears clear with no issues but fronts just touch the brakes. I will be getting 5mm spacers machined and installed in a few days. This is a temp solution until my H&R or eibachs spacers come in - but first I need the temp spacers to see what mm branded spacer to get.
So there goes additional $$ but its my fault so im going to bit the bullet.
I dont have the wheels now as they are all but one in my friends garage tucked under a blanket. The 4th one is in my trunk to be given to the shop to machine a temp spacer. So no pics yet (breaks my heart to see it mounted/balanced on ps2's)
Its a good thing I got hub centric rings from Work - one headache my instinct had me foresee.
Old Jul 8, 2007 | 01:29 PM
  #92
Originally Posted by Gdup35sedan
clint, what pad did you order on the front? Those should fit with no problems in that offset. A 5mm spacer will do and you'll still be able to use the stock studs. Lets get a pic of the wheels!
-GP-
btw using these Work open ended lug nuts
http://i141.photobucket.com/albums/r.../rays_lugs.jpg
Old Jul 9, 2007 | 12:40 AM
  #93
skeleton_cru's Avatar
Sedan
That's what I thought.
Old Jul 9, 2007 | 03:06 AM
  #94
redlude97's Avatar
If you only need a 3mm spacer, any generic spacer purchased at an autoparts store will work fine. They are universal, and aren't hubcentric, but they are only 3mm wide so they'll work without any problems. Going to 5mm and you'll need to change out your stock studs for longer ones to be safe. Other than that, brand doesn't make a significant difference, H&R, eibach, Ichiba all make similar spacers in 5mm.
Old Jul 22, 2007 | 12:16 PM
  #95
GreenGoblin's Avatar
The goblin resurrection
use some standard washers on the studs to measure (do not drive on them) then use a caliper to see the exact clearance you need. On a side note is the abu dabhi on the cornish?
Old Jul 22, 2007 | 12:20 PM
  #96
thanks man. i got the hr 5mm spacers with extended bolts
https://g35driver.com/forums/g35-sedan-v35-2003-06/166177-my-work-vsxx-gold-project-failed-today-spacers.html
abu dhabi is another city in UAE. Where in S. Flordia do u live? i love s.fl in the summer+winter+fall etc... best place to chill and party!
Jusseth
Sep 13, 2020 12:25 PM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
tiguy99
Jul 26, 2015 01:39 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
Ninjay16
Jul 20, 2015 01:21 AM
