Urgent help with tire sizes please
Old May 23, 2007 | 01:12 PM
clinthammer's Avatar
I am ordering the Works VS-XX gold 19's for my ride tomorrow morning and no one has posted back regarding proper tire sizes here:
https://g35driver.com/forums/wheels-tires/155953-my-final-works-vs-xx-sedan-thread-offset-help-needed-please.html
19x8.0+38 Adisc tire 245/40-19
19x9.5+42 Odisc tire 245/40-19 (may be better to have 255/35-19; Both stays inside of fender)
A disc is 2" lip and o disc is around 3 inches.
What tires sit flush with the fender and do not rub. I am not lowered and suspension is stock.
Thanks for the help. Looking to be the first sedan with gold works
Old May 23, 2007 | 01:31 PM
KrazyEd's Avatar
Most people go 245/35/19 for the fronts and 275/30/19 for the rear.
Old May 23, 2007 | 01:42 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
clint,
i remember you saying that you werent going to lower your car at all. If that is the case then I'd recommend getting some tires with more meat than you normally would. I'd go with the 245/40 up front and a 265/35 or 275/35 in the rear. Those sizes will help with the wheel/fender gap that you are going to have.
-GP-
Old May 23, 2007 | 01:52 PM
thanks
yes i doubt i will lower it. im sure i will have gap with 19"s but i can't afford to go low because of my garage at work and general road conditions.
i don't know why Works Japan recommended 245/40 in the rear. Does the width difference of 30 (275-245) make a differencE?
Old May 23, 2007 | 01:55 PM
They recommended that because its the "in" thing to run stretched tires. The difference between a 245 and 275 is that the 275 is 30mm wider of a tire (which you want because your rear wheel is wider than your front)
-GP-
Old May 23, 2007 | 02:00 PM
(>")> G35's Avatar
I went 245/40 front, 275/35 rear.
I need new pics...
if not lowered would
1. 245/45 in front rub?
2. 275/40 ot 45 rub?
Old May 23, 2007 | 02:01 PM
> G35
are you lowered?
any rubbing issues on front or rear?
Old May 23, 2007 | 02:03 PM
(>")> G35's Avatar
I'm not lowered at all and no rubbing issues. the fronts are +38 and rears are +45 in offsets.
Old May 23, 2007 | 02:05 PM
those sizes are too big, you'll like you're rolling on 17's. Stick with the 245/40/19F 275/35/19R
-GP-
Old May 23, 2007 | 02:12 PM
im just worried about the 35's on the rear being too thin and blowing up
so the big q - how much performance loss should I expect?
Old May 23, 2007 | 02:20 PM
(>")> G35's Avatar
^It'll be fine with the 35 in the rear...
https://g35driver.com/forums/g35-sedan-v35-2003-06/140541-got-my-new-wheels-no-pics-yet-though.html
Old May 23, 2007 | 02:31 PM
thanks everyone. i think ill go for 245/40 and 275/35 now.
>G35 - you mentioned as soon as you drove out you noticed sluggish pickup and braking... do yo still notice it and does it really affect a lot?
i dont race or track but i need to kill some 5 series once in a while
Old May 23, 2007 | 02:44 PM
ttrank's Avatar
Grocery getter
Yes I would run a 245/40 and 275/35 if you are not going to lower it.
The extra 30mm in the back is huge and 245's on that width would look like crap.
Old May 24, 2007 | 03:15 AM
I went to the tire size site to compare tires:
http://www.wheelsmaster.com/rt_specs.jsp
Here is the comparision:
275/35/19
Suspension: Package is 27 mm (1.1'') closer to suspension/brakes components. Make sure that you have enough room for that. If not, consider lower offset, narrower tires or using spacers
Fenders: Package will stick out 33 mm (1.3'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
Wheelwells: Will fill out the wheelwell by extra 4 mm. Almost no difference
245/40/19
Susp: Package is 8 mm (0.3'') closer to suspension/brakes components. Acceptable for most cars.
Fenders: Package will stick out 22 mm (0.9'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
Wheelwells: Will fill out the wheelwell by extra 6 mm. Acceptable for most cars.
