help: question about tires!
Old Jun 26, 2007 | 03:08 PM
arjunz's Avatar
Having two different types of tires. For example: Bridgestone potenza's in the front and michellin ps2's in the rear.. what sort of implications would i face? such as ride quality etc.. Thanks in advance.
Old Jun 26, 2007 | 03:09 PM
mike281's Avatar
Mike Team350GZ
not sure exactly, but I know nothing good comes of it handling wise.
Old Jun 26, 2007 | 03:32 PM
joe603's Avatar
If you get similar quality tires, I'm sure the effect will be minimal.
Old Jun 26, 2007 | 04:39 PM
avs007's Avatar
I had Potenzas on my rears and Pilot Sports on my fronts about a week ago. VDC kept flipping out on me, and steppin gin to brake one of my front tires, causing the rear to step out, in mild curves.
I think it had less to do with traction differences and more to do with size differences. According to tire-rack, even though the tires are the same size, there was actually a 1/10" difference in the diameter of the tire.
Old Jun 27, 2007 | 09:44 AM
ISMSOLUTIONS's Avatar
There shouldn't be any issue, as long as the tires are similarly rated. The PS2's are far better tires than the Potenza's - and they are also louder - so your max benefit and driveability will be with a full set of PS2's...
Rick
Old Jun 27, 2007 | 10:40 AM
express705's Avatar
i agree with ISM.... your not going to get the same ride quality anyhow.. and plus.. the tread wear isnt going to be the same. the potenzas are a softer tire, which means faster wear.
Old Jun 27, 2007 | 10:45 AM
bocatrip's Avatar
It's done all the time. No major issues if they are the proper size and rating. I have it now with absolutely no problems.
Old Jun 27, 2007 | 10:53 AM
QKRTHNU's Avatar
Yokahama
I use 295 30 ZR on the rear and slightly smaller in the front the Yokahama Advan Sport is an awesome tire, I run 680 RWHP and half done the season tires are like new!
Old Jun 27, 2007 | 11:10 AM
BTW - I have PS2's in front and TR1's in the rear - got tired of killing $400 tires in the rear every 3-4 months...
Old Jun 27, 2007 | 11:13 AM
rcdash's Avatar
How do the Toyo's compare to the PS2 in terms of traction and noise?
What width do you run?
Old Jun 27, 2007 | 11:16 AM
As far as I can see, with heating them up, etc, they work REALLY well. The noise level is about the same as the PS2's - you really can't tell any difference, and the traction is about 90% of the PS2's.
I have 295/30/19's on the rear.
I'm impressed enough to change the front out to them when they wear down, and I've been a Michelin guy for about 20 years, and tire shop owner in the past...that speaks a lot about them, I think.
Rick
Old Jun 27, 2007 | 07:19 PM
rcdash's Avatar
I just spent $800 on just 2 PS2 tires, 295/35/18 and I was so close to trying the proxies for 1/2 the cost...
Next time I will - thanks for the review.
Old Jun 27, 2007 | 11:23 PM
Oh yea..one more benefit to the Michelin's..they will last about 30% longer...
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
