TE37's and the correct offset for me is???
Old Aug 28, 2007 | 01:01 PM
805g's Avatar
What's up all, i just recently found out that a friend of mine can get me a deal on some volks.
I'm hoping to get some gold te37's.
I am lowered on tein s-techs, and tokico shocks, 2003 (so i've got some brembos).
What's my best bet for offset?
+20???
Old Aug 28, 2007 | 01:04 PM
Hi-TechG35's Avatar
+23 is decent.
Old Aug 28, 2007 | 01:05 PM
Alan's Avatar
i got +22 all around. its perfect! if you want a bit more lip in the front you can go even lower i think. ive seen a car with gold le's with a polished lip and a good bit more lip than mine. its anybodys guess as to what offset he ran in the front.
(9.5 front, 10.5 rear)
Old Aug 28, 2007 | 03:44 PM
leemik's Avatar
+22 is perfect, or even +12 if you can make it fit..
The old Team Emotion topsecret body kitted white G35 has +12 LE37's (pretty much same rim as TE37) and the look super aggressive
--mike
Old Aug 28, 2007 | 04:17 PM
Triple8Sol's Avatar
+22 all around on 9.5/10.5 will be good. Pretty flush and allow you to run decent tires like 255/285.
Old Aug 28, 2007 | 05:16 PM
805g's Avatar
Thank you alllll! thanks so much.
Old Aug 29, 2007 | 12:33 PM
805g's Avatar
any fender rolling necessary?!?
Old Aug 29, 2007 | 01:28 PM
Calvin's Avatar
Overglorified Altima
depends how much you're dropped and how much camber you're willing to run. you can get away without shaving the fenders - easily.
i shaved mine.
10.5 +24
285/35
as low as i can go with my basics
-1.5 camber
Old Aug 30, 2007 | 04:57 PM
805g's Avatar
HELP sos HELP sos JUST LOOK!
HELP!!!!
I've just realized that the 19x9.5 and 19.10.5 +22 offset won't clear my stock brembos IS THIS TRUE??!?!?!
Old Aug 30, 2007 | 05:01 PM
805g's Avatar
it says here:
http://rayswheels.co.jp/cgi-bin/cgi2...modelName=TE37
that the 10.5 +22 won't clear my brembos. What's the dealllllll. what should i do?!?!
Old Aug 30, 2007 | 06:22 PM
redlude97's Avatar
Originally Posted by 805g
it says here:
I think those won't clear the front brembos, they aren't addressing the rears there. Martyg35 has the +22 setup IIRC with OEM brembos
Old Aug 30, 2007 | 09:50 PM
martyg35's Avatar
+22 clears Brembos and various BBK setup ..I miss my old setup sometimes..haha
Picture Share
Feb 4, 2018 12:41 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
TurTLe*
Sep 29, 2015 01:43 PM
