Tire Size Recommendation
Old Sep 10, 2007 | 11:38 AM
Az1aN's Avatar
Question Tire Size Recommendation
04 G35 6MT w/ Brembos
F: 19x9 +27
R: 19x10 +22
Car is currently on stock suspension, pending on how much of a wheel gap, ill lower it in the spring. I want some meaty tires since NJ roads suck.
PS: Should I get spacers?
Old Sep 10, 2007 | 11:54 AM
Nismo G's Avatar
255/35/19 - Front
285/30/19 - Rear
offset seems not very aggressive...
-Sean
Old Sep 13, 2007 | 12:34 PM
Az1aN's Avatar
Originally Posted by Nismo G
255/35/19 - Front
285/30/19 - Rear
-Sean
Tirerack suggests i use:
255/35-19 front
285/35-19 rear
any noticable difference?
Old Sep 13, 2007 | 05:06 PM
lowrider's Avatar
255/35/19 - Front
285/30/19 - Rear
-Sean
This is bogus information. The "G" until 2007 had a built in stagger in the outer diameter of the front to rear wheels. Your VDC expects to see about a 1" difference in the OD from front to back. Using the above sizes will kill the stagger. The proper sizes are 245/35/19 front and 275/35/19 rear. Your recommended sizes of 255/35/19, and 285/35/19 are perfectly fine. Also, your offsets, IMO, are OK, but just a tad aggressive in the rear. You could have a rub, but probably wont.
Lou
Old Sep 13, 2007 | 05:08 PM
redlude97's Avatar
Lou
+1
Old Sep 13, 2007 | 05:17 PM
RBull's Avatar
Rated M
Lou
The 275's would help a bit too.
Old Sep 13, 2007 | 07:03 PM
Az1aN's Avatar
so in conclusion, which setup would be better for me?
255/35/19 front and 285/35/19 rear
Sorry guys, I'm such a newbie at tire sizes.
Old Sep 14, 2007 | 12:18 AM
lowrider's Avatar
(a) 245/35/19 front and 275/35/19 rear
(b) 255/35/19 front and 285/35/19 rear
IMO, the (a) option would lessen the chances for a rub on the rears. Both sizes will fit fine on your new wheels.
As for a tire recommendation (I know, you didn't ask) I'm running Dunlop SP Sport Maxx and luv 'em.
Lou
Old Sep 14, 2007 | 12:21 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
You can fit the 255/285 combo perfectly fine, your offset in the rear isnt aggressive, its pretty flush. Roll the fenders when you drop it and you'll be all set.
-GP-
Old Sep 14, 2007 | 12:30 AM
BayAreaRefuGz's Avatar
i fly low
~!sorry to hijack thread!~
if i wanted deep dish rims, should i aim for negative (-) offset?
Old Sep 14, 2007 | 12:32 AM
gary c's Avatar
Tire sizes with your rims.........!
I have 245's in front and 275's out back on the same rim offset you have. If
I push it on a very tight down hill right hander the left tire rubs even with my
sways and strut bar....so I'm carefull! I'd like to see where it hits but it's
almost impossible to duplicate sitting still.
Old Sep 14, 2007 | 12:57 AM
redlude97's Avatar
I'd like to see it
Old Sep 14, 2007 | 01:06 AM
i fly low
I'd like to see it
are you saying it's not possible.
Old Sep 14, 2007 | 01:09 AM
redlude97's Avatar
I said I'd like to see it, and not on skinny wheels either or with super stretched tires
Old Sep 14, 2007 | 01:17 AM
warzywko's Avatar
i got 255/40/19 front and 255/40/19 back on stock rims and the front looks bigger thats only temporary
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
