Do I need a Spacer?
Old Nov 15, 2007 | 02:36 AM
Granto86's Avatar
Do I need a Spacer?
If I have an 04 sedan with stock 17s on right now, and I put a pair of oem 19s on, will I need spacers? What size and how much will they cost?
Old Nov 15, 2007 | 02:45 AM
Beebo's Avatar
you dont need spacers but you could use them (you may rub in the rear) im not sure about the size but H&R is a good brand
Old Nov 15, 2007 | 02:49 AM
VIPLINE's Avatar
u can go to H&R webside and they have the detail specs on it. Make sure u get the hub-centric spacers like H&R, not the crappy cheap ones.
Old Nov 15, 2007 | 03:13 AM
Klubbheads's Avatar
no spacer is needed for OEM 19s. Its 33 offset 8.5 inch wheel. U just need to shave/roll ur fenders.
Old Nov 15, 2007 | 10:55 AM
Granto86's Avatar
Will that cost extra to do during the installation?
Old Nov 15, 2007 | 11:09 AM
CandlestickPark's Avatar
ill Sedan
Are you lowered or on stock suspension? If you are not lowered then you shouldn't have any rubbing issues in the rear.
Regarding the cost to roll your fenders, I'm running Coupe 19s as well and will be dropping my car in the next two weeks. I was quoted $40 per side, so $80 total. For those of you that have had this done, does that cost sound about right?
Old Nov 15, 2007 | 11:16 AM
Klubbheads's Avatar
It does NOT matter if he is lowered or not. The springs compress enough to rub.
As far as the price go, I payed $50 for both of them. They shaved it though.
Old Nov 15, 2007 | 11:20 AM
ill Sedan
Really, all of the other posts I've read on this subject suggest that if you are on stock suspension then you shouldn't have any issues rubbing. I'm not lowered (yet) and I've had 4 adults in my car with no rubbing issues.
Old Nov 15, 2007 | 11:22 AM
Klubbheads's Avatar
that is wierd, because when my fenders were not shaved and i was on stock sport suspension, it would rub when i would take a corner with only 1 person in the back. A lot of times i did NOT hear it because it is very minor. My friend told me once and i payed attention and heard that it was rubbing.
Old Nov 15, 2007 | 11:24 AM
ill Sedan
That is weird. I'll have to listen more carefully.
Where did you get your fenders shaved? How did you decide to shave vs. rolling?
Old Nov 15, 2007 | 11:27 AM
Klubbheads's Avatar
Did not see the point of rolling because the climate does NOT get below freezing in socal so they is no rusting issues.
F1 motorsports, in North Hollywood did the work.
Old Nov 15, 2007 | 02:55 PM
Granto86's Avatar
Okay, so it seems that I I am going to have to roll/shave them, but honestly I have no idea what that means ha.. Which one should I do? And where could I get that done in south florida?
Old Nov 15, 2007 | 04:45 PM
Klubbheads's Avatar
Post that question in ur regional section and im sure a lot of people will have answers as where to take ur car to get it done.
Old Nov 15, 2007 | 04:51 PM
Granto86's Avatar
Should I roll or shave them? And do I do that before I put the wheels on?
Old Nov 15, 2007 | 04:53 PM
redlude97's Avatar
IMO, roll>shave. You can DIY also, its not that hard, look in the DIY section
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
