OEM 19" with 265/30/19 Tires
Old Mar 26, 2008 | 09:30 AM
minus500's Avatar
Can anyone tell me if I can run a 245/35/19 tire in the front and 265/30/19 on the rear? I bought the wheels for my 03' Coupe and want to get some wider tires before I put them on. Would 235/35/19 and 265/30/19 be a better combo?
Also, will this throw off the VDC? I believe the car came with 17's from the factory. Thanks guys.
Old Mar 26, 2008 | 03:32 PM
redlude97's Avatar
265/30/19 is WAY to short. If anything you should use 265/35/19 although that is too wide for an 8.5" wheel according the manufactures specs. I would go 245/35/19 and 255/40/19
Old Mar 26, 2008 | 04:46 PM
Beebo's Avatar
^+1
Old Mar 26, 2008 | 07:24 PM
minus500's Avatar
Why? If I use a 245/35 front and the 265/30 front, the front/rear bias is nearly the same as stock albeit the speedometer will be off a bit because the new combo has smaller overall diameter. The 3% rule isn't violated though and I thought that is whats important. TELL ME SOMEBODY! Thanks.
Old Mar 26, 2008 | 07:25 PM
redlude97's Avatar
Go read up on aspect ratio and then come back
Old Mar 26, 2008 | 07:26 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
the 30 series is too small. You'd need atleast a 35 series tire in the rear. And whoever told you 265 is suitable for an 8.5" wide wheel (according to tire manufacturer's specifications) is wrong.
-GP-
Old Mar 26, 2008 | 07:36 PM
minus500's Avatar
I'm already aware that the aspect ratio is the ratio of sidewall height to tire width. How does that apply here? I wish you could have given me an explanation. Oh well.
Old Mar 26, 2008 | 07:38 PM
minus500's Avatar
-GP-
There are several threads on here where the max width on OEM 19's has been discussed and it seemed like most agreed that a 265 would work on the rear but a 275 would not even though several members had the 245/275 set-up with no problems.
Old Mar 26, 2008 | 07:39 PM
ttrank's Avatar
Grocery getter
265 on the 8" front is too wide for that rim.
Old Mar 26, 2008 | 07:46 PM
Just because you can put it on doesnt mean you should. I could mount a 295 on an 8.5" wheel and still drive on it, doesnt mean it would be safe.
Do a little research..
the stock 245/40/19 tire is 26.72" in diameter and a 265/30 is 25.26", you're taking away 1.46" in diameter and it could likely mess with your VDC. especially if you put a 245/35 up front which is 25.75" in diameter (0.49" greater than the 265/30 you want on the rear)
So you want a smaller tire on the rear than on the front? I fail to see where that makes any sense what so ever.
As stated by redlude, if you want wider tires on your OEM 19's, the best size combo would be a 245/35 front and 255/40 rear.
-GP-
Old Mar 26, 2008 | 07:47 PM
minus500's Avatar
No, I know that. I'm talking about running 245/35(8") and 265/30(8.5") combo. This is almost the same bias as stock only shorter. I can live with the speedo being off.
Old Mar 26, 2008 | 07:49 PM
expect for the fact that what you want to put on makes the rear tire a half inch smaller in diamter than the front. The stock setup has it the other way around bud
-GP-
Old Mar 26, 2008 | 07:51 PM
minus500's Avatar
-GP-
Yeah, my fault. I was thinking that the front factory was 225/45 but I see that its 225/40. Does that .5" make a difference in VDC. I still don't think it violates the 3% rule even though its .5" in the other direction. What combo will work with 265/30? I appreciate your help on the subject.
Old Mar 26, 2008 | 07:54 PM
If were talking about the same OEM 19" wheels manufactured by Rays with the Bridgestone RE050a tires on them that came with all 05-07 sport coupes, then the tire sizes are 225/40 front and 245/40 rear.
-GP-
Old Mar 26, 2008 | 07:56 PM
minus500's Avatar
-GP-
Yep yep. See my post above. I just edited it.
