Probably beat to death...but..sedan offset?
Old Mar 27, 2008 | 11:55 PM
Infaltry's Avatar
I've got a line on some tight 20x8.5 with a 34mm offset...will these work on my 05 G35x? its probably been assked a thousand times but I just can't grasp the concept of how offset works without racking my brain too hard...a 34mm offset sticks out further than say...a 30mm offset correct? so with a 34mm...spacers wont help me...I think
Old Mar 27, 2008 | 11:58 PM
NewYorkG35x's Avatar
yes
Old Mar 28, 2008 | 12:01 AM
Infaltry's Avatar
Originally Posted by NewYorkG35x
yes
thank you for that very informative reply.
Gdup35sedan's Avatar
ENVautoDetailing.com
the lower the offset, the further the wheel sticks out.
for an 8.5" wheel with a 245 tire you can use an offset anywhere from 30-45 and it will fit. The lower the number, the more flush it will sit.
-GP-
Old Mar 28, 2008 | 12:03 AM
Infaltry's Avatar
-GP-
so I should be ok with a 34mm offset and a 2 inch drop and camber kit? or will I have to leave the negative camber to clear the wheel wells?
Old Mar 28, 2008 | 12:05 AM
With a 2" drop, you should still be able to get back to -1.0 camber with that setup.
-GP-
Old Mar 28, 2008 | 12:08 AM
Infaltry's Avatar
thanks man
Old Mar 29, 2008 | 01:54 PM
with a 2" drop you gonna have rubbing issues you might have to get your fenders rolled.
Old Mar 29, 2008 | 02:21 PM
Infaltry's Avatar
I'm gonna go with a 38 or 40mm offset just to be on the safer side.
Picture Share
Feb 4, 2018 12:41 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
TurTLe*
Sep 29, 2015 01:43 PM
