Another sedan on Coupe 19" but with stock height
Old Apr 15, 2008 | 09:13 PM
  #31
g35freak86's Avatar
Originally Posted by WannabeSport
I want my coupe 19s now 17s suck
I hear ya. 17's suck. 19's for the summer... here I come!!!!!!
Old Apr 15, 2008 | 10:54 PM
  #32
eric300zx's Avatar
Thanks! They are stock I believe... 225/40 fronts and 245/40 rears.
Originally Posted by Texan1
^looks fantastic, soo much better/cleaner/sharper.
what is your tire size again?
Old Apr 15, 2008 | 11:01 PM
  #33
eric300zx's Avatar
Nice G 02themax!
Were you able to get the alignment back? How is the H-techs compared to
to stock sport springs, in terms of ride quality?
Originally Posted by 02themax
Lowered with htechs, 19 coupes, no fender rolling, no rubbing. Click my link below for pic.
Old Apr 16, 2008 | 01:42 AM
  #34
VQ Hotness's Avatar
WTF is going on.. Alright im returning my car to stock and i take off my basics+400.00 and trade with a friend for 07 coupe suspension + Coupe 19's with tires. Im thinking my car is going to be perfect ride hight ready for me to sell with a two finger gap all around.
I lower the car off the jacks and the rear is a 1 finger gap with the front being a freaking hand. Looks like im lanching at 4k off the line with slicks, which would be fine but the cars turn off in my driveway. Am i glad i didnt put my oem suspension back on or i would be heading out to the mudd pits.
So i guess im going to be looking to buy some springs here soon so this thread should help me out.. I want the car to sell fast so im hoping some clean oem rims plus a lagit drop will help the sell.
Old Apr 16, 2008 | 01:51 AM
  #35
02themax's Avatar
Originally Posted by eric300zx
Nice G 02themax!
Thanks Eric, I got the alignment back to within specs. The Htechs are a bit soft in the rear but the ride quality is like stock! I should've went with Eibach's but once I installed sways it helped tighten things back up. Thanks for the compliments!
Old Apr 16, 2008 | 09:49 AM
  #36
g35freak86's Avatar
I'm in a debate between the eibach pro kits and the tein 350z h techs. which would you prefer? I will be on coupe 19's most likely and I don't want to have crazy camber issues. Rubbing I can deal with, since I will roll the rear fenders. You think I should just go with the eibach's first time around???
Old Apr 16, 2008 | 01:14 PM
  #37
lexusk8's Avatar
I have Eibachs for my setup (sitting on 19x8.5 all around). With no camber kit(s) installed yet, I was able to get the alignment dialed in to 1 deg negative camber on the front, and little less than 2 deg negative camber on the rear. I believe this is close to the coupe specs, and since I don't daily drive my G and don't put in a lot of miles, this is fine for me.
Old Apr 16, 2008 | 08:49 PM
  #38
eric300zx's Avatar
That's great! I don't mind it being a little softer. I don't really like the bone jarring feeling when hitting bumps with the stock sport springs. As long as I
get the sway bars too , I think it will work perfectly for me.
Old Apr 17, 2008 | 11:26 AM
  #39
NismoSER's Avatar
^Any pics showing how your tires sit in comparison to the rear fender?
Not really, but here's what I've got:
Attached Thumbnails Another sedan on Coupe 19" but with stock height-coupe19s.jpg
Old Apr 17, 2008 | 11:30 AM
  #40
Texan1's Avatar
Q50 Red Sport 400 RWD
Originally Posted by NismoSER
I'm running 255-35-19 on coupe 19s in the rear with a stock suspension for now, and I only rubbed if I had passengers in the back and hit big dips/bumps. I rolled the fenders in the rear a smidge, and no more rubbing.
what tire size in front do you have?
Old Apr 17, 2008 | 07:10 PM
  #41
ttrank's Avatar
Grocery getter
Originally Posted by HUMBOLDT_G
Ya I don't think that set-up isn't going to work if you lower it, the coupe offset is way off. Your gonna have rubbing issues if you lower it, plus you don't want your friends to laugh at you. This link will help you out, it has everything you'll want to know.
https://g35driver.com/forums/g35-sedan-v35-2003-06/196616-look-here-before-starting-new-thread-2003-2006-sedan-faq-s.html
Your setup will work fine with the correct tire sizes. At stock height you should not have any rubbing issues, but if you lower it you should plan on getting your fenders rolled. If you roll your fenders you won't have any issues with rubbing.
From the FAQ thread:
Q - Will coupe 19's fit an 03-06 sedan?
Yes, however, if you lower your car you will need to either run smaller than OEM tires or roll/shave your fenders to avoid rubbing in the rear due the coupe 19's lower offset.
THANK YOU
It's nice to see some people take a few minutes to see if their question is answered in the FAQ before asking it again...
Old Apr 17, 2008 | 07:59 PM
  #42
eric300zx's Avatar
Ttrank, your FAQ answered a lot of my questions. Thank you!!!
The only concern I had was when I lowered the car with the 19" wheels, the gaps where a bit too much compared with the stock 18's. That was why I asked for photos of G's running on stock heights. Now I just gotta decide on which springs to get and also roll the fenders.
Old Apr 17, 2008 | 08:34 PM
  #43
g35freak86's Avatar
Tein 350z H techs, Eibach Pro kit, or Coupe/Z drop. Those are the best options dropped on coupe 19's that won't require a camber kit and can get or close to oem specs on camber
Personally I am going with the pro kit.. 1.0" all around
You will most likely need to roll the rear fenders if you drop on any of those springs I mentioned above if you are on the coupe 19's
Jusseth
Sep 13, 2020 12:25 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Thunderaan
Jul 22, 2015 07:40 PM
mushu
Jul 15, 2015 03:55 PM
