vibrations while driving
Old Apr 7, 2004 | 12:04 PM
lance_888's Avatar
I just put some new wheels on my car but I have a slight problem. I have added 245/35/19 all around on my sedan. Driving under 55mph I do not feel any vibrations. Once I get over 55mph, my steering wheel starts to vibrate. Going above 60mph, i can feel even more vibrations. Any experts think I need to take this to some place for balancing?
thanks
lance
Old Apr 7, 2004 | 01:14 PM
The_Driver's Avatar
Re: vibrations while driving
If you find an answer let me know....I'm having the same problem with 245/40-19's all around.
Old Apr 7, 2004 | 01:21 PM
wizawuza's Avatar
did you try checking the torque on the wheels? For my coupe I make sure it's at 80 ft-lbs on the lug nuts.
Dunno if that's your problem, but I do know that loose lug nuts will cause your car to have similar symptoms.
2004 Twlight Blue/Willow 6mt Coupe.
Bel Vector 985 Hardwired.
Grounding Kit.
Splash Guards.
Next Project: Carputer.
Old Apr 7, 2004 | 03:31 PM
GoSooners's Avatar
Just hope your wheels are unbalanced. If not that, your rim may be damaged/warped. I hydroplaned my car into a curb at about 50 mph in the rain on my stock 17s. From then on, I felt vibrations at about 55mph and above. The faster I go, the more the streering wheel vibrates. This was due my warped wheel. Once I got a new set of wheels, it stopped.
Black on Black 5AT Coupe, Navi
Axis Milanos 19x8.5 F 19x9.5 R
Toyo T1S 255/35 F 275/35 R
HKS Legamax Exhaust
350Z Duct
Stillen Hi Flow
7 Wire Hypergrounding Kit
Old Apr 7, 2004 | 05:18 PM
khsonic03's Avatar
You probably need some hubcentric rings which are cheap and an easy fix. Aftermarket wheel companies make the wheels to fit a variety of vehicles. Hubcentric rings fill up the void around the hub and center the wheel so you don't get vibrations, etc.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, Gram Light 57F Pro's (on the way), Hotchkis sways, Borla
Old Apr 7, 2004 | 05:23 PM
Buddha's Avatar
you need hubcentric rings.
04 G35C 6mt/aero kit/nav/premium
Old Apr 7, 2004 | 06:59 PM
Anonymous's Avatar
I agree. Hubcentric rings should do the job. They did the job for me. The factory hub measurement is 66.2
Anonymous's Avatar
Old Apr 7, 2004 | 10:17 PM
lance_888's Avatar
Thanks for the reply guys, I'll try the hubcentric rings. Do you think the local tire shop have these rings? i.e Firestone or NTB
Old Apr 11, 2004 | 11:10 AM
multimut's Avatar
Re: where to find the rings
Not every tire shop will carry the rings. Check with a wheel/tire dealer that carries that make of the rim that you have, or if the wheel manufacturer has a web-site you might be able to buy direct. A good wheel/tire dealer that carries the make should have the right size rings.
If you bought the wheels new, then the folks that sold the rims to you should have asked what car you're buying for, and then provided hub-centric rings automatically. Some shops that don't automatically provide rings, but the better ones will include them automatically.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
Frostbite91
Aug 20, 2015 07:20 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
