285/35/19 Rear Tire on Coupe
Old May 8, 2008 | 10:13 PM
N/A Project's Avatar
-2006 IP GT350-
I'm getting a new set of tires (got dang negative camber).
Currently, I'm running 255/35/19 front and 275/35/19 rear tires. I'm thinking to go a little wider like 285 or even 295 in the rear but I'm not too sure if it's going to fit. I know I may have to cut/roll fenders but that's ok.
Doen anyone have coupe pictures with wider tires than 275 in the rear on stock body?
Thanks,
JJ
Old May 8, 2008 | 10:16 PM
silver g's Avatar
I believe Calvin is running 285's. Not sure though. Check the picture share section...he's all over that.
Old May 8, 2008 | 10:18 PM
Calvin's Avatar
Overglorified Altima
285/35
Old May 8, 2008 | 10:28 PM
-2006 IP GT350-
Thanks man.
Cal,
Sexy 1 ill G there. Any more pictures showing side fender against tire wall? And your wheel is 10.5, correct? Did you have to roll your rear fenders? Any rubbing?
JJ
Old May 8, 2008 | 10:30 PM
silver g's Avatar
^That's what I thought. Question for ya Calvin...did you have to roll the fenders to run those tires?
Old May 8, 2008 | 10:45 PM
Calvin's Avatar
Yes, they're 10.5" wheels. That picture was taken back when I was dropped on Tein 350z H-Techs. I believe my camber settings were -1.5. Rear fenders were cut.
Originally Posted by J-J
Thanks man.
Cal,
JJ
https://g35driver.com/forums/picture-share/168372-inven-roof-spoiler.html
https://g35driver.com/forums/picture-share/161771-before-hero-goes-black.html
https://g35driver.com/forums/picture-share/141927-another-rainy-day-socal-part-two.html
See if any of those pictures are what you're looking for.
Old May 8, 2008 | 11:18 PM
-2006 IP GT350-
Thanks once again Calvin.
JJ
Old May 8, 2008 | 11:19 PM
Calvin's Avatar
Did you find what you are looking for?
Old May 8, 2008 | 11:26 PM
-2006 IP GT350-
Yes, more meat with a little sticking out over the fenders...nice. Great pictures by the way.
I think I'll go with 285.
Do you think 295 can survive on stock rear fenders? Since you are here full-time, have you seen someone done that before?
JJ
Old May 8, 2008 | 11:29 PM
Calvin's Avatar
JJ
I've seen people go up to 305 on stock fenders.
I was planning on going 295 with my next set, but I decided to step it down to 275 so I can put larger (10mm) spacers in the rear for a more aggressive offset.
Old May 9, 2008 | 12:08 AM
Sylvan lake V35's Avatar
My old set up 285/35 on 10.5"wheel fenders cut and rolled
new set up 285/35 on 12" wheel
Old May 9, 2008 | 09:17 PM
-2006 IP GT350-
^^ Thanks man. Nice G.
JJ
Old May 9, 2008 | 09:28 PM
Triple8Sol's Avatar
285/35/19 BFG KDW2
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
nascarbuff17
Jul 16, 2015 10:23 AM
