Wheel spacers, just need a little clarification before I bite the bullet.
Old May 12, 2008 | 08:51 PM
Lolly Baggins's Avatar
Okay I will be purchasing Project Kics 20/25mm spacers for my G35 Coupe. It's on stock suspension and 19" stock rims as of right now.
http://www.frsport.com/Project-KICS-...rn_p_3028.html
These are the ones I am thinking about purchasing. Will be fine just buying them and slapping them on, correct? No need for a hub centric spacer or anything? (Whatever that is.. LOL)
Thanks. Looking to purchase as soon as I get some confirmation. Thanks again.
Old May 12, 2008 | 11:56 PM
jigahus's Avatar
This place sells em cheaper.
http://www.autornd.com/catalog/produ...3055914be98623
Old May 13, 2008 | 12:02 AM
Boston's Avatar
I would reconsider and go with a hubcentric spacer. H&R makes a hubcentric in both 20 and 25MM. The Kics posted will put the weight of the wheel directly on the studs rather than on the hub.
Old May 13, 2008 | 12:41 AM
Where can I find these?
Old May 13, 2008 | 02:37 AM
Triple8Sol's Avatar
AutoRnD sells hubcentric rings with their KICS spacers for an additional $20 per set. Just add that.
Old May 13, 2008 | 10:08 AM
Boston's Avatar
^That'll work. I'm sure if you plug in the vehicle info, you will get the correct hub bore needed.
Old May 13, 2008 | 11:46 AM
jigahus's Avatar
Yup do that and your golden.
Old May 13, 2008 | 11:47 AM
Awesome! Thanks guys.
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
