Hotchkis sways crunching sound
Old Apr 20, 2004 | 04:19 PM
crashTestDummy's Avatar
Do any of you with the Hotchkis sways (that didn't get any of the supposedly included grease tubes) have a crunching sound from any front and back car movement. Like when you come to a stop, accellerate, go over a speed bump, or over a dip?
I can really hear mine, when drving slow with the windows up and no music. We've check all the bolts and clearance and have narrowed it down to the bushings rubbing against the bar .... grease? hmm .. maybe.
DP G35 coupe/ AT / Prem graphite / Sport / Titanium 19 tint / 5 wire hyper-ground kit / clear corners / hyper white clearance/ i-Pod mini silver
San Diego, CA
Old Apr 20, 2004 | 05:16 PM
Blk_G35's Avatar
Re: Hotchkis sways crunching sound
I had terrible problems with squeaking noises when I got mine installed. The idiots at the shop I got it installed at, put them on with no grease (I have no idea if the bars even came with any even though the instructions says clearly to put grease on the bushings BEFORE installation). The rear bar has this cool fitting that lets you couple a standard grease gun and a shot or two later it's completely greased. My back bar is now completely silent. The front bar is a b*tch to get to and it uses the stock fittings. So unfortunately I'm going to have to take my car this weekend to someone that knows what they're doing so they can remove the front bar and do it right.
Old Apr 20, 2004 | 05:33 PM
protocav's Avatar
crashtestdummy,
good luck finding someone who knows what they are doing...sheesh.
did you call hotchkis and order some of their joy-jelly?
Old Apr 20, 2004 | 05:35 PM
I called Hotchkis and am having them send me some of their grease. We used some other brand grease on the install ... but don't think it's cuttin it. keep us posted Blk_G35.
San Diego, CA
Old Apr 20, 2004 | 06:49 PM
glennp_1999's Avatar
I got mine with everything in it and I made sure that I put more than enough of that silicon grease. So far so good no noise coming from the undercarrage.
<font color=blue>04 CB COUPE / WILLOW / PREM PACK</font color=blue>
Old Apr 20, 2004 | 08:38 PM
khsonic03's Avatar
It is very important that you use the correct grease for the front. It is specific for urethane pieces. I know you can buy Energy Suspension (urethane) bushings/etc. from Pep Boys. Maybe they carry their grease as well. Might want to give it a shot. I used prothane grease for the front (I didn't get any grease with the bars), and I have had NO problems with noise, etc. For the rears, I used a SYNTHETIC grease from advance auto. Great stuff.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, Gram Light 57F Pro's (on the way), Hotchkis sways, Borla
Old Apr 21, 2004 | 05:22 PM
D_Nyholm's Avatar
Yeah, you just need to grease the front bushings. It is actually really easy. Just get under the car, remove the under engine cover, remove the 4 14mm bolts from each bushing (be careful when you remove the last one since the bar will swing down FAST if you aren't holding it), then pull each bushing off and load up the inside with the sticky white grease. Reinstall and you will not hear a peep from them!!!
http://usastreetracing.com/images/vi...aos2teaser.wmv
DOWNLOAD THE TEASER VIDEO BY CLICKING ON THE LINK
Old Aug 3, 2004 | 12:27 PM
SixFive's Avatar
What was the verdict on solving this one? Grease? I had my fronts tightened as they worked themselves loose after about a week. Grease alone wouldn't make the noise you describe as it sounds like yours were loose too? ?
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
dcsbh1
Oct 1, 2015 03:15 PM
