How good are the stock Brembos?
Old Apr 30, 2004 | 06:23 PM
jts1207's Avatar
Any gains from an upgrade?
Old Apr 30, 2004 | 06:30 PM
Z2G's Avatar
Z2G
Re: How good are the stock Brembos?
to be honest, i think even the stock 5at brakes are pretty good. i haven't driven the 6mt with the brembos yet but i'm sure it would be even better. i think unless you're planning on going to the track, either are great for around the town.
if you want better performance with the brembos, i believe there are past posts on brake pads that you can get to improve performance.
Old Apr 30, 2004 | 07:23 PM
DragonGcoupe's Avatar
I heard the 5AT brakes are even more sensitive, if not as powerful. The Brembo's are good for :stopping fast. Ohhh man. My first test drive I slammed on those babies at 55mph to stop. =)
Black / Black 2004 GcoupeMT. Premium. Splash Guardz.
Old Apr 30, 2004 | 07:52 PM
al503's Avatar
Braking performance is dictated by the tires in our G's. The main difference between the stock and brembos (and brembos to aftermarket big brake kits) will be resistance to fade. 1 stop from 60-0 will yield very similar results between all three mentioned. After 5-10 stops in succession, the BBK's will perform incrementally better than the stock and brembos because they can absorb more heat.
Old Apr 30, 2004 | 08:41 PM
afr0puff's Avatar
Supa Dupa Moderator
20,000 miles and two auto-x's under my belt... no complaints here. Not a squeak/wear indicator noise from them bad boys yet.
http://www.anythingbox.net
Old Apr 30, 2004 | 10:01 PM
lowrider's Avatar
IMO, the non Brembo brakes are overly sensitive without good feel, they are just too touchy. But, again that's JMO. I can't say enough good thing about my Brembos, OTOH. I think they are a great set of brakes (my only complaint being the dust). The feel is fantastic, their resistance to fad is top notch. In short, they are the best brakes I've ever used.
Lou
Old Apr 30, 2004 | 10:45 PM
Wanted to add. I thought the Brembo's were overly sensitive in the beginning, however once I became acquainted with those babies, it brakes perfectly smooth until the last notch, where the real braking power will kick in.
Old Apr 30, 2004 | 11:50 PM
6mtInCharlotte's Avatar
Saved my butt a couple times. Although the Bridgestones help alot.
Old May 1, 2004 | 02:09 AM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
Pads and Upgrade the Brake lines to Braided Stainless........Oh and MOTUL Racing Brake Fluid
GOT N20?
CPV35 Driven BY David K, VQ35DEN Tuned By DR CHARLES
...........NismoCPV-35
Old May 1, 2004 | 02:15 AM
I think the best thing for me, is the aggressive stance that the Brembo calipers portray.
Old May 1, 2004 | 08:23 AM
Catatafish's Avatar
al503 is right. The Brembos will not stop you any faster than the stock set up. They are only more resistant to fade.
It's all about the tire in this instance.
2004.5 Coupe/5AT/Ivory/Everything but chin spoiler/Z Tube-Popcharger/Crawford V5 Plenum on the way
Old May 2, 2004 | 07:03 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
I changed my front brakes out at around 7 or 8K miles to some brembo calipers/larger rotors. So I've had plenty of miles with both the stock brakes and with some brembos. My front calipers are also based off the Brembo lotus caliper like the 6mt ones. The difference is FADE. With it, you feel that you have more control of when exactly you want to stop. Both braking systems are more than good enough for regular street use.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
Frankieg35
Mar 20, 2016 09:42 PM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
