Can I buy tires two at a time???
Old Jul 29, 2008 | 10:44 PM
diitto's Avatar
Hi... I posted elsewhere here recently about my search for tires to replace the Bridgestone Potenza's that came on the car new... I have settled (I think) on trying Kumho Ecsta spt's... My rear tires are close to needing to be replaced but my front tires still look like they could go another 10,000 miles... Will the car operate ok (VDC, etc) if I first buy two Kumho's for the rear (stock size) and keep running the Bridgestone's on the front??? My reason for wanting to do so is two fold... First, 10,000 good miles left on the front tires isn't chump change to throw away... And second, it might give me the chance to see if the Kumho's are decent tires or not.... Grnated, still having the Bridgestones on the front I won't be able to learn everything you would want to know about the Kumhos but still I think I could learn something... Like if the ride is better or worse after changing two tires, then you'd learn something about those two new tires... Maybe...
Anyway, will the VDC work ok with different brands, amount of tread and tread patterns front versus back??? Any help would be much appreciated... thanks... bob...
Old Jul 30, 2008 | 08:32 AM
reverse's Avatar
it should be ok. i rode on stock 18's front & aftermarket 19's rear for a week w/out the vdc going off. my IS250 though is very sensitive to tire wear & sizes.
Old Jul 30, 2008 | 09:07 AM
Mitsuko's Avatar
theres a chance u mite experience this, but all case its liveable and now it doesn't happen as often as it did when i posted this
https://g35driver.com/forums/wheels-tires/223481-need-help-vdc-acting-up.html
Old Jul 30, 2008 | 02:59 PM
Triple8Sol's Avatar
Yes. Buy the right sizes and speed ratings, and you should be ok.
Muski_G
Dec 1, 2023 11:11 AM
itschuckster
Jul 25, 2015 08:07 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
