new rear tires, now car feels odd
Old Aug 5, 2008 | 12:17 AM
rob40wilson03's Avatar
I just had my stock rear tires replaced (with the Kumho Ecsta SPTs at stock sizes) and still have the stock fronts. I just got them put on last week but had only been driving around town. Today I went on a 4 hour drive, primarily on highways. Anyway, at highway speeds, my car feels funny now... any slight steering input makes the whole car feel like its wobbling or something.... hard to explain, but almost feels like shimmying the steering on a wave runner/sea-doo. By the end of the drive I didnt notice it as much but maybe I was just getting used to it, idk??
Is this just a result of the tires not yet being broken in, or is there something else going on here??
Thanks as always!
Old Aug 5, 2008 | 12:20 AM
mIKE's Avatar
Softer sidewalls than the Factory RE050a's.
Old Aug 5, 2008 | 12:38 AM
this is a bummer.... i already dont like it, i feel like the car is less stable now
hopefully i will get used to it quickly
Old Aug 5, 2008 | 12:56 AM
elayman's Avatar
could be that since your front tires are worn down, they are 1-2 mm smaller than your rears so they feel a little funky?
just my guess
Old Aug 5, 2008 | 02:30 AM
LBC77's Avatar
did you get an alignment?
Old Aug 5, 2008 | 09:47 AM
LightsOut's Avatar
SIETESG
i think its just the oil residue thats on the tires since there new. give it about 200 miles or so and it will feel normal agian.
and you wont need an alignment.
Old Aug 5, 2008 | 02:36 PM
no... didnt get an alignment
HOPE it gets to feeling normal soon
Old Aug 5, 2008 | 04:01 PM
sredish's Avatar
is it possible that the SPTs just grab traction a little differently and are more responsive to steering input? I'm running the SPTs (much wider and lower profiles) and they definitely grab a little more and are much more sensitive to the steering input. I figured it was the width that was doing it but it could be a combo of the tires as well. I really like the tires but they do have a different feel than the stockers and it's probably the softer sidewall like Mike mentioned. Put a little more air in them and see if it helps.
Old Aug 5, 2008 | 05:07 PM
i will try that!
will the softer sidewalls make the car any less safe..... say, when im taking my favorite circular on/off ramps at aggressive speeds? (aside from the fact that the tires are in fact new and need to be cautiously adjusted to)
Old Aug 5, 2008 | 09:06 PM
sredish's Avatar
not really any more unsafe than any other tire but I do feel that with too low of pressure, they'll have a tendency to roll and push just a bit during hard cornering...
Old Aug 5, 2008 | 09:58 PM
GeeDM's Avatar
i would figure that the thread of the front tires is trying to pull the car one direction and the rear thread is trying to pull the car another direction...making the car feel like it is unstable...happened to me one time when i had 2 different sets of tires on my 240....just my thought.
Old Aug 6, 2008 | 06:38 AM
idrive_MD's Avatar
mixing tire types is more than likely your problem try to get a matching pair of the SPT's up front...its geneally a big no no for a daily driver to be mixing different tire types
Old Aug 6, 2008 | 12:34 PM
st1sj's Avatar
best to replace all 4 tires at same time, or under/over steer could be the result, depending on which end you replace.
TWASkyliner
Feb 8, 2020 08:00 PM
wojowojo16
Jul 27, 2015 09:57 AM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
quickspeed6
24
Jul 15, 2015 11:06 AM
