Need an expert to confirm: Offsets / Tires
Old Aug 13, 2008 | 03:29 PM
hanguk9117's Avatar
I've searched the forums, read the faqs on offsets, and i'm pretty sure i have a fairly good understanding. This site really helped too: http://www.rims-n-tires.com/rt_specs.jsp
I picked up a set of rims, pretty good deal, fairly cheap:
Front: 19 x 8.5, +20 offset
Rear: 19 x 9.5, +30 offset
I have the oem tires on there right now, but I plan to put on 245/35-19 for the fronts, and 275/35-19 for the rears. With this setup, adding a 10MM spacer to the rear will put the offsets at +20 all around correct? Will that be sufficient to have all the wheels flush?
Old Aug 13, 2008 | 03:32 PM
redlude97's Avatar
is this a coupe? You will need 25mm spacers in the rear to make them "flush", and 15mm in the front.
Old Aug 13, 2008 | 03:39 PM
hanguk9117's Avatar
Yup this is for a coupe. I'll need the 25mm spacers (rear) and 15mm spacers (front) even with the larger tire sizes?
Old Aug 13, 2008 | 03:47 PM
redlude97's Avatar
those aren't larger sizes. I ran a 9.5+30 with a 25mm spacer and a 285/35/19 and still cleared with a fender roll
Old Aug 13, 2008 | 03:50 PM
hanguk9117's Avatar
wow ok. that's what i'll do. thanks red!
Old Aug 13, 2008 | 04:04 PM
redlude97's Avatar
Here is how flush it is with the 25mm spacers
Here is how tucked the 9.5+30 is without the spacer
This is with SPC camber arms set to -1.5/1.6
Old Aug 13, 2008 | 04:09 PM
hanguk9117's Avatar
that is a huge difference. okay, so +5mm offsets all around would be best, hence the 15mm up front, and 25mm in the rear. thanks again for the help red.
Old Aug 13, 2008 | 05:00 PM
hanguk9117's Avatar
hm, i don't think my camber is as negative as yours. that might make the 25mm too much right?
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Machine Head
Sep 4, 2015 07:22 PM
Fire0nic3
Aug 31, 2015 03:18 PM
