Ok to replace one rear tire?
Old Sep 8, 2008 | 08:42 PM
smokedhen's Avatar
Both of my rear tires have nails in them. The driver's side tire got pactched and is doing fine now. The one on the passenger side got a nail in the sidewall, but it was not losing air. The idiot at the tire shop went ahead and took the nail out anyway. Do I have to replace both rear tires or is there a less expensive solution?
Old Sep 8, 2008 | 08:52 PM
Nismoboy's Avatar
i would say get both the rears for safety reasons.. patched tires are usually ok for a long time.. usually the remaining life of the tire itself.. but a puncture in the sidewall is iffy... no big-chain shop (i.e. discount tire, ntb, firestone, tiremax, etc) will repair a sidewall puncture unless you go to a really small non-chain shop that'll put a plug in it.. but then that isnt completely 100% safe either.. just from experience, i rode on a plug for at least 10k miles before and they say plugs last about a year possibly more.. but that was on a set of tires i had a long time ago.. i dont have those tires anymore
plugs are very inexpensive.. most small shops will charge maybe $5 to $10 max
Old Sep 8, 2008 | 11:26 PM
smokedhen's Avatar
did you plug a sidewall puncture?
Old Sep 9, 2008 | 12:00 AM
Nismoboy's Avatar
yea it was the sidewall i got plugged
Old Sep 9, 2008 | 12:03 AM
GLuXuRy's Avatar
sidewall punctures ARE NOT REPAIRABLE AT ALL .. PERIOD
if your tires are brand new .. then just get that one tire
but if rear tires are some what close to being needed .. then just get them and depending on your mileage .. i suggest a allignment
Old Sep 9, 2008 | 12:09 AM
Nismoboy's Avatar
yea i dont recommend pluggin the sidewall either.. but just coming from past experience when i needed a quick affordable fix until i was able to afford a new set of tires.. thats what i did.. it worked okay for me for about 10k miles.. but i could of just been lucky... i don't think i'll ever do that again
Old Sep 9, 2008 | 04:29 PM
stevek247's Avatar
SAme problem here smokedhen!!!
I decided to get it plugged... but doesn't look too pretty... i think the bump will settle though.. hopefully
check it out the post...
https://g35driver.com/forums/g35-sed...h-tires-2.html
Old Sep 9, 2008 | 08:01 PM
smokedhen's Avatar
why the alignment?
Old Sep 28, 2008 | 01:47 AM
smokedhen's Avatar
For futre reference: according to tirerack.com, an alignment is usually not needed after you change two rear tires unless your car previously already needed one. They also said that it would be ok to replace one rear tire if the tread wear of the other tire was at least 5/32. Mine was 4/32, so I purchased Bridgestone Potenza Pole Positions.
I read up on a lot of the reviews on tirerack left by g35 drivers, and this was the best pick. If you want to save yourself hours of reading the reviews, just buy the pole positions and call it a day. Ironically, if I had listened to the rep to buy the pole positions, I would have saved myself a lot of time and stress.
btw, after a day or so of drive 70 mph on the highway, I learned that it is recommended that you drive 50 mph on the spare. haha. I even deflated the spare to 36 psi, because I didn't know that you're suppose to inflate it to 60 psi. I guess the sticker on the spare has some purpose.
Thanks for everyone that helped
rezendvous420
May 31, 2020 01:26 PM
vitamin.v
Nov 7, 2019 06:10 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
emorehs
Jul 17, 2015 09:45 AM
nascarbuff17
Jul 16, 2015 10:23 AM
