Tire Sizes with 20's?
Old May 19, 2004 | 10:50 AM
nitty917's Avatar
What is everybody running on their 20x10 and 20x8.5?
Thanks!
Old May 19, 2004 | 11:04 AM
Vic's Avatar
Vic
Re: Tire Sizes with 20's?
you should put 245/35/20 for the front and 275/30/20 for the back..
TB/Black, 6MT coupe, Aero, Premium, Navi, Pop Charger + Z-Tube, Clear Corners, 30% tint.
Old May 19, 2004 | 03:54 PM
mamboking's Avatar
According to what I have learned in various threads. The ideal setup is to keep the 1 inch difference in diameter from the front to the back just like the stock wheels. This is what the VDC system is programmed to handle. If you can do a 275/35/30 without rubbing, the difference in diameter is not exactly 1 inch but it is close. 26.75f to 27.58r.
Getting a lower profile on the rear tire is a standard practice when trying to keep both tires at the same diameter since the extra width of the tire provides more height. However as stated above, if you care to keep the VDC system working properly I would advise against getting the 30s on the back.
Old May 19, 2004 | 04:56 PM
waijai's Avatar
i.love.gold
If you run 245/35 & 275/30 the rears will be smaller. You do not want a shorter overall diameter in the rear. I just ordered 255/35 & 275/35 for my iForged 20s on the way.
Ivory Pearl coupe
Old May 19, 2004 | 05:28 PM
Vic's Avatar
Vic
I think if you want to lower the car, using 275/30/20 is better. 275/35/20 is a little bit to thick and may rubbed if the car is lowered.
but if you dont lower your car, 275/35/20 will be great.
Old May 19, 2004 | 05:44 PM
nitty917's Avatar
dont plan on dropping the car. what shuld i go with
<P ID="edit"><FONT class="small"><EM>Edited by nitty917 on 05/19/04 02:45 PM.</EM></FONT></P>
Old May 19, 2004 | 06:10 PM
Vic's Avatar
Vic
I think you should get 275/35/20. it will look odd if you use 275/30/20 and not lowering it.
Old May 19, 2004 | 07:14 PM
nitty917's Avatar
what bout fronts?
Old May 19, 2004 | 09:12 PM
Vic's Avatar
Vic
the front you can use 245/35/20.
Old May 20, 2004 | 08:14 PM
wreck's Avatar
Running for his life!!
245 for my fronts and 285 on the rear.. personally I don't know why people don't run 285's in the rear unless their favorite tire manufacture does not support that size.
G35C 6MT / AMG E55
Old May 20, 2004 | 09:44 PM
Vic's Avatar
Vic
the main reason I did not put 285 in the back was because I did not want to roll my fenders. The car is dropped, so if I don't roll my fenders and put 285 in the back, it will rubbed. thats why I just put 275.
Old May 20, 2004 | 10:42 PM
wreck's Avatar
I see.. well I guess it depends on the offset.. Cause I have 285's and I don't rub. I actually have rooms for 295's, but they don't make tire at that spec with the right profile.
G35C 6MT / AMG E55
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
