g37s wheels on 1st gen g35 lug nut question.
Old Oct 15, 2008 | 03:09 AM
SlickG's Avatar
People that put g37s wheels on their 1st gen sedan or coupe, do you guys need shank lug nuts? I'm not sure if the g37s use shank lug nuts instead or spline drive lug nuts. The reason why i am asking is because the other day i took off my wheel and i saw metal shavings coming off slightly. I am using the stock lug nuts that came with the car. please help. thanks in advance
Old Oct 15, 2008 | 03:32 AM
Nickk6's Avatar
Make sure you are not cross threading your nuts onto your studs.
Old Oct 15, 2008 | 06:20 PM
SlickG's Avatar
for sure it's not cross threading it, it goes in and out smooth, until it hits the rim.
Old Oct 15, 2008 | 07:30 PM
G35Papa's Avatar
You torquing to 80lbs?
Old Oct 15, 2008 | 07:36 PM
Canadian's Avatar
Canada, eh?
If you can torque it to 80lbs, you're fine. Also as they said make sure you're not cross-threading it, or else you will need a new stud.
Old Oct 15, 2008 | 09:26 PM
Kazaam's Avatar
Originally Posted by Nickk6
Make sure you are not cross dressing, or sliding your nuts into some studs.
Fixed!!!!!!1 LMAO!!!! Sorry guys, I'm bored outta my azz... This debate is wack, McCain is is a pu$$y!!!
Old Oct 15, 2008 | 09:39 PM
SlickG's Avatar
yes, i torqued it to 80lbs. maybe im trippin, but i will call infiniti and ask tommorow.
Old Oct 15, 2008 | 09:50 PM
Carlito's Avatar
x2 sad tired old man...
Old Oct 15, 2008 | 11:21 PM
psedog's Avatar
Back in SD**
I agree with you guys on the debate, but lets keep it in the off topic threads.
https://g35driver.com/forums/politic...ml#post3534098
I think you'll be fine. Just inspect your threads and ensure that they are alright. If you doubt them at all, change your studs. Trust me it is a b#*&# to clean up after a lugnut is frozen. (8 hours of drilling )
Also, wheels don't have anything to do with your lug nuts/stems.
Old Jan 17, 2011 | 08:06 PM
Gtz1stballer92's Avatar
i have the same problem. im looking at buying extended wheel nuts
Old Jan 27, 2011 | 07:02 PM
Tyrone-Biggums's Avatar
You weren't clear when you you said you were "using the stock lugs that came with the car".
You're gonna be hating life real soon if you used the cone type lugnuts that came off of YOUR car (G35)!
The 37's use a shank style lug and from what I have read I would stick to the OEM vs aftermarket as some are saying the fit with aftermarket is a little sloppy.
You can find them on EBay for $1 - 1.50 each
Old Jan 27, 2011 | 09:13 PM
dumbg35x's Avatar
you would need the g37 shank lug nuts
Old Jan 27, 2011 | 09:30 PM
richardcvan's Avatar
so he would need these?
http://cgi.ebay.com/ebaymotors/20-Sh...ht_1445wt_1167
Old Jan 28, 2011 | 12:11 AM
Chief.Crappin.Squirrel's Avatar
i would just use OEM lugs i found that out the hard way cuz any regular lug wont fit at all. the g37 lugs are totally different and just so u know they are about 150 from dealer for the set
Old Jan 28, 2011 | 09:40 AM
Here is a link on ebay - Just put select "best offer" and start with a dollar or so and see what he takes
http://cgi.ebay.com/ebaymotors/infin...Q5fAccessories
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
si_driver
Jul 14, 2015 12:29 PM
