Possibly getting new rims soon.... a few questions...
Old Nov 23, 2008 | 10:46 PM
Nightm4re's Avatar
I am searching for new rims and i have a few questions....
Depending on the size and offset of the rim, how do i know what size tire i should be looking for? The rims im hoping i can get for a reasonable price are either..
19X8.5 19X9.5 +25 +30
OR
20X8.5 20X10 +25 +30
How do i know what size tire would look good without rubbing or needing me to roll the fenders? and sizes... how wide & what size sidewall should i be expecting to keep a comfortable ride without feeling EVERY bump?
One other question. When looking at rims, how do i know how wide the lip will be in the back? for example, on the 20's listed above, is the front 8.5mm lip and a 10mm lip in the back? and what do the offsets mean?
Thanks for the input!
Old Nov 23, 2008 | 11:39 PM
Triple8Sol's Avatar
If you have a coupe, those are really weak fitments. You're going to want to run some sizable spacers.
Old Nov 23, 2008 | 11:43 PM
chord42's Avatar
10 mm? think about how big a millimeter is for a sec
Old Nov 24, 2008 | 12:36 AM
Nightm4re's Avatar
didnt think about the mm thing haha....
and what kind of spacers do you think id need? what are good fitments??
Old Nov 24, 2008 | 01:50 AM
Nightm4re's Avatar
I used the tire calculator here and i didnt really see how it would be an issue..
http://www.bigcustomwheels.com/rt_sp...&text1=&text2=
Would this set up work?
20X8.5 rims with 255/30/20 front and 20X10 rims with 285/30/20 rears
Should i get a +25 offset in the front and a +30 in the back? Or +25 all the way around or would a +30 offset be better? Or should i get a +30 offset and get 15mm spacers? I really appreciate an answer because ive searched for hours and couldnt get a clear answer....
The car is an 06 coupe so i dont have to worry about them clearing brembos or anything, and the car is not lowered.... will i have any problems with them rubbing?
these are the rims-
Old Nov 24, 2008 | 02:07 PM
EL-EE-ES's Avatar
id get +25 around, 30 is the offset of oem wheels i belive
Old Nov 24, 2008 | 02:22 PM
Nightm4re's Avatar
so it should be ok wihout any rubbing with the +25? Any info to back up why you'd choose 25 instead of 30?
Old Nov 24, 2008 | 02:29 PM
Ghayes23's Avatar
With those sizes a +25 offset would be the best. You might rub with a 285 especially if you lower it eventually, and you're gonna want to lower it after getting those wheels. I'd recommend that you go with a 275 out back.
Old Nov 24, 2008 | 10:02 PM
EL-EE-ES's Avatar
i have a set of 19x9.5 and 19x10.5 with +20 all around on order...+30 the wheels would be tucked like the stock rims,+25 would push the rim out for a more flush look. are you lowered or plan to lower?
Old Nov 24, 2008 | 10:21 PM
ahussain's Avatar
have these wheels with a +25 offset all around, no rubbing at all tho im running Falken 452's 245/35 up front and 275/30 on the rears
im dropped on tein s-techs, i f u wanna c pics go to the northern cali Car picture share thread... page 13 post # 190 or rather...here
https://g35driver.com/forums/norther...-share-13.html
seagrasser
May 3, 2022 09:43 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Adon
Sep 22, 2015 03:56 PM
