lancer evo brembo brakes
Old Jun 2, 2004 | 07:07 PM
areddy14's Avatar
does anyone know if the 6mt g35c brakes are bigger than the lancer evo brakes? a friend of mine told me that the wrx sti brembos are the same size as ours.
cb/graphite g35c - fully loaded
jwt pop charger - 350z tube
Old Jun 2, 2004 | 07:35 PM
ducatiadam's Avatar
Re: lancer evo brembo brakes
if anything the STI brakes would be larger than ours.
exhuast, intake, Clear Bra, Race pedals, momo ****, Eibach Sway Bars & Springs, Piaa 4150k, 15% tint, Bronze Volks CE28N 19" 245/275,
Custom Leather Interior
Old Jun 3, 2004 | 12:12 AM
al503's Avatar
I believe the STI, Evo and the G's brembos are all the same 'Lotus' model. You can't interchange them (you could but it wouldn't be worth the trouble) however because the bias is set up differently in each my each manufacturer.
Old Jun 3, 2004 | 11:20 AM
tig488's Avatar
the evo brakes are different, a friend of mine has an evo and he has red 6-----thats 6 piston fronts, his rears are the same as ours.
having sig issues at the moment.
Old Jun 3, 2004 | 11:47 AM
al503's Avatar
I stand corrected. There was a discussion about this on my350z.com and the consensus was that they were the same but the bias would be off. I guess they were wrong.
Old Jun 3, 2004 | 01:15 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
The calipers are all based on the Lotus caliper, but that doesn't make them identical. Externally, the Evo and Sti calipers have the brake fluid routed through an external line, while the G35/350z calipers have the fluid routed internally. The pistons on the G35/350z are 38/44 mm, while on the Evo/Sti I think they were 40/46 mm. Finally, the G35/350z mounting bolts are 10cm apart, while on the Evo and maybe Sti they are about 12.5 cm apart. It is this last point that makes it very very difficult to even get the Evo/Sti caliper mounted on a G35.
I have some red Brembo Lotus calipers on my car, which I was told came off an Evo. But externally, it looks more like a G35/350z caliper with the internal brake fluid routing. And the mounting bolts were 10 cm apart. Otherwise, I would not be able to even mount it onto my car. I'm not sure of the piston sizes, but looking at pics of stock G35 brembo pistons, they look the same. I still have the same pedal effort/travel, just much much reduced fade now. I'm using stock 350z track/G35 6mt brake pads.
Old Jun 3, 2004 | 06:36 PM
tig488's Avatar
ny friends evo brakes look just like the brembo gran turismo bbk, about 2 inches longer than ours.
Old Jun 3, 2004 | 11:12 PM
areddy14's Avatar
so which brembos are better? lol.
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
