rim bent a little, bad to leave it alone?
Old Dec 12, 2008 | 06:07 PM
Nightm4re's Avatar
my rear passenger side rim has a bend on the inside lip from a pothole... It looks like the tire pushed the energy outward and slightly bent the outter lip which is barely noticible. There are no bends on the inside of the wheel at all, and the tire isn't losing any air. Would it cause any damage if I decided to leave it alone? So far, I've had no vibrations at speed up to 90mph...
Just wanted some input.
Old Dec 12, 2008 | 06:16 PM
Nightm4re's Avatar
Also, the guy at sears auto center checked it out when I had an alignment done and he said the worst thing that could happen is that it isn't balanced 100% and might vibrate, but it doesn't so there doesn't seem like any reason to spend $125 to have the rim heated up and repaired.
Old Dec 12, 2008 | 06:22 PM
Law to the Rence's Avatar
Old Dec 12, 2008 | 06:24 PM
Nightm4re's Avatar
it's dark out now, I'll get pics tomorrow morning.
Old Dec 12, 2008 | 08:55 PM
Nightm4re's Avatar
Ok here are the pics
the red lines match up to about where the bends are... as you can see, nothing in there is affected by it
Old Dec 12, 2008 | 09:15 PM
G in NY's Avatar
that is mad small. I had somthing like that ended up getting it fixed
Old Dec 12, 2008 | 10:00 PM
NJzFinestG's Avatar
if ur car dosent vibrate leave it alone. worst case is it vibrates a lil at high speeds or might have a small leak.
iv had a 1/2" crack and 2 bends in 2 of my front rims on my last car. it vibrated a lil but nothing too noticable. but the 1/2 inch cracks made it leak air on bot my rims. i filled it 3 times a day for a month with a portable air pump until i got sick of doing that n bought rays wheels lol.
Old Dec 13, 2008 | 06:11 PM
Mustang5L5's Avatar
Originally Posted by Nightm4re
I could see the seal breaking here if you hit a good sized pothole again. Might not happen, but that's a pretty good size bend right there.
I'm **** and would replace the rim.
Old Dec 13, 2008 | 07:59 PM
EL-EE-ES's Avatar
+1 on the seal and pothole. it doesnt look bad...but i would get it fixed for peace of mind.
Old Dec 14, 2008 | 06:43 PM
Triple8Sol's Avatar
Get it fixed
vitamin.v
Nov 7, 2019 06:10 PM
Danielek
Sep 20, 2015 12:08 PM
mryogi
Aug 20, 2015 04:10 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
vstypicals
Jul 20, 2015 10:55 PM
