Thinking of running 245-35-19 on all 4 coupe wheels for my sedan
Old Jan 7, 2009 | 07:28 PM
  #31
G SEDAN's Avatar
Some tires are directional but symmertrical, but you can still swap them from side to side case in point: Falken 451, 452s.
Some tires you cannot swap side to side, they actually state on the sidwall which sides are outside, or Inside. Those tires I guess are Asymmertrical?
Case in point: Falken Azentis (sp?)
Old Jan 7, 2009 | 07:33 PM
  #32
Rodrigo's Avatar
^ correct Nitto tires are the same way.
for the most part you will find that in most high performance summer tires that will never see snow or ice.
Old Jan 7, 2009 | 07:37 PM
  #33
G SEDAN's Avatar
most summer tires i've had have always been Symmetrical directional (Falken FK 451, 452, Yokohama AVS). I can rotate them side by side with my staggered setup
Tires that are asymmetrical are going to be directional no matter what so with a stagger setup, you cant rotate AT ALL (Falken Azentis). With nonstagger setup, you can only rotate them front and back. You will be azzed out if you have innter camber wear.
Old Jan 7, 2009 | 08:17 PM
  #34
redlude97's Avatar
Symmetrical=symmetric. (ie mirror image) Falken 452, Toyo T1R etc
Assymetrical=not symmetric Bridgeston re050a, Vredenstein etc
Directional is a whole other classicafication.
Some assymetrical tires can be flipped, such as the re050a, which does not have an inside or outside patter designation, while others cannot as pointed out above.
Old Jan 9, 2009 | 05:58 PM
  #35
Jeff92se's Avatar
Red Card Crew
Originally Posted by G SEDAN
directional FTW! the vanes look seek foo!
I'm getting these in 225-40-19 and 255-35-19
Old Jan 9, 2009 | 06:32 PM
  #36
redlude97's Avatar
you should go 245/35/19 in the front instead. Same height, but much better handling
Old Jan 9, 2009 | 07:10 PM
  #37
G SEDAN's Avatar
245/255 stagger sounds good.
Old Jan 10, 2009 | 01:04 AM
  #38
Texan1's Avatar
Q50 Red Sport 400 RWD
yep.
Old Jan 10, 2009 | 03:33 AM
  #39
tite_tite's Avatar
Originally Posted by Rodrigo
you could run them it will be slightly off speedometer .
im running 245 40 19 front 255 40 19 rear rides great and fills the gap well
do you by any chance have pics of your ride w/ your tires setup? i have the rays too but riding 245 40 19 all around. with my current setup, my front wheels looks bigger than my rear. i liked the stagger look but was trying to save $$$ on tires
previously, i had 225 40 19 front & 245 40 19 rear. it looked good but way too much gap in the front.
thanks.
Old Jan 10, 2009 | 10:27 AM
  #40
Rodrigo's Avatar
^ ill post some pics, you will love it , I do.
Many will disagree but i think for the sedan on OEM 19 its the perfect fit.
Old Jan 10, 2009 | 01:19 PM
  #41
G SEDAN's Avatar
255 40 19 sounds like you need to have your fenders rolled flat for sure
Old Jan 10, 2009 | 04:23 PM
  #42
Jeff92se's Avatar
Red Card Crew
I just grabbed a set used for $700. Dude only put 1500 miles on them as he went with a wider tire on his M3. I couldn't pass up that deal. So that was the sizes he had.
Old Jan 10, 2009 | 04:40 PM
  #43
G SEDAN's Avatar
we all know 1500 miles is more like 4000 miles \
LOL
Old Jan 10, 2009 | 05:11 PM
  #44
Jeff92se's Avatar
Red Card Crew
eh. The tires still smelled new. They still had the new tire nipple things on the edge and measured out to about 9/32nds. They are really almost like the picture above (which is brand new)
Old Jan 10, 2009 | 05:13 PM
  #45
G SEDAN's Avatar
what are they? Michelin pilot sports?
