Thinking of running 245-35-19 on all 4 coupe wheels for my sedan
Old Mar 10, 2009 | 01:10 PM
  #61
Jeff92se's Avatar
Red Card Crew
Originally Posted by Klubbheads
Those are some major savings. I wonder how much weight i will save if i swap my RE050 runflats with T1Rs or your tires.
T1Rs for reference to my sizes. Both are about 25 lbs.
http://marktg.toyotires.com/file/18966.pdf
But in general, the Bridgeston RE050s are fricken heavy. I have no idea why Infiniti put the lighter Michelin Pilot sports on their heavy cast wheels and turns around and puts the heavy arsed Re050s on their FORGED Rays. That combo makes both weigh about the same!
Old Mar 10, 2009 | 01:42 PM
  #62
ihaveamustang's Avatar
Originally Posted by Jeff92se
Here's a pic with the oem 225-40 and 245-40 19s on. Coupe rear/Z front springs.
I'll post pics of the new setup when I actually mount these on the G. Still a slight threat of snow here.
The rear 255s aren't nearly as wide as I would have thought. And the 225 fronts seem narrower then the bridgestones.
Sorry man - I read that several times and thought I saw 245/40 on the front for some reason.
I thought you were going to run 245/40 F and 255/35 R.
Thanks anyway for posting the pic.
Old Mar 10, 2009 | 03:53 PM
  #63
Klubbheads's Avatar
Re050s are heavy so imagine how much havier their runflats are.... which came on my 335.
Old Mar 10, 2009 | 07:39 PM
  #64
godmans's Avatar
Awesome. That's the 2nd person to mention no rubbing issues w/ the 255-35 combo. Other guy was running Kumhos in that size.
Who thinks we should have a tire test sticky in our little section? I could post a 2005 R&T tire test and I found a tire test from Europe that looks at the Verdenstien tires (rated #1 on that test).
255/35/19 at the back doesn't rub provided that you fold in the rear fender a tad. I was on Michelin PS2 btw.
Old Mar 10, 2009 | 07:40 PM
  #65
godmans's Avatar
For handling, I will keep the RE050 any day....
Old Mar 10, 2009 | 07:44 PM
  #66
Klubbheads's Avatar
Your personall opinion. I can argue otherwise but won't.
Old Mar 10, 2009 | 08:19 PM
  #67
Jeff92se's Avatar
Red Card Crew
I liked the RE050s. Dry/Wet performed well. Decently quiet. But the treadwear and weight are negatives to me.
Tirerack reviewed them and it didn't figure in all that great.
http://www.tirerack.com/images/tires...y_f1_gs_ds.pdf
The only Michelin was the PS2s which I don't have. But the winner of the TR test was the Goodyear eagle F1 GS-D3.
There was a test comparing the F1s and the older Pilot Sports I got above.
http://www.tirerack.com/tires/tests/...ay.jsp?ttid=45
Considering I got these used, I'm really happy with what I was able to get vs my criteria (price/quality/size/treadwear)
Old Mar 11, 2009 | 12:15 AM
  #68
mr_ecktid's Avatar
i just got 245/40/19 sumitomo htrz iii all around
Old Mar 11, 2009 | 08:36 PM
  #69
ttrank's Avatar
Grocery getter
I have 245/40's on my oem 19's right now and hate the way they look. I would much rather have 35's.
Old Mar 13, 2009 | 04:13 PM
  #70
Jeff92se's Avatar
Red Card Crew
I agree. But with a treadwear of 140, you'll get your chance shortly.
Old Mar 23, 2009 | 03:56 PM
  #71
Jeff92se's Avatar
Red Card Crew
Finally got them mounted. And just because I'm a weight *****:
oem RE050s:
225-40-19 = 25 lbs.
245-40-19 = 30 lbs.
Michelin Pilot Sports:
225-40-19 = 21 lbs.
255-35-19 = 24 lbs.
I saved 4 lbs off the fronts. 19s & tires = 43 lbs. vs 47 lbs.
I saved 6 lbs of the rears. 10x & tires = 47 lbs. vs 53 lbs.
All weights are probably +/- 1 lb or so.
Not bad for a 220 utog vs 140 and a better tire review.
For reference, my oem 17 wheel and blizzak 215-55-17 came in at 45lbs each. I'm lighter them oem in front and just a tad heavier in the rear. Not bad for going +2 and 10mm / 40mm wider!
Update. One concern was the 255 rear widths. But I've run this setup for a few days and it doesn't rub (thanks to all that also ran 255-35s and have commented).
One think I've noticed is that the Michelins seem to be a narrower tire. The fronts look almost stretched even though I'm running 225s still. The rears don't look any wider than the RE050 245s.
Handling is hard to comment on as I've been running the blizzaks for the last few months. Performance? Again hard to tell how it compared to the oem RE050s. But my impression is that there isn't much performance drop from the stocks/blizzaks to these 19s/Michelins. I remember swapping last year and noticing a much bigger drop in performance when I put the 19s/RE050s back on. The weights above confirm my thoughts too. BUT the 255-35 is a touch smaller than the OEM 245-40 it replaced (which could also account for some difference). But a 6lb weight savings from the outside diameter of the rotating mass has to make a difference.
Old Apr 9, 2009 | 11:49 AM
  #72
Jeff92se's Avatar
Red Card Crew
Update. I've been averaging about 19.5 mpg. When I swapped to the 19s with the RE050s, my mileage would go down to the 18 mpg range. So I "think" these lighter tires do make a slight diff.
I've also added the RU airbox so I don't know if that made any diff but I doubt it consider how hard I hammer the throttle now Which makes the 19.5 mpg all that more impressive. lol
Old Apr 9, 2009 | 09:12 PM
  #73
Triple8Sol's Avatar
You should be stretching 215's on there!
No, no you shouldn't.
Old Jun 1, 2010 | 01:36 PM
  #74
Jeff92se's Avatar
Red Card Crew
Update. Wanted to get my tires swapped but the fronts were too worn on the inside and the rears were at the wear bars. ugh.
Ended up shelling out $1200 for a set of Michelin Pilot sport all seasons. Still decently light and swappable. and with a 500 utog.
Since I had to decide right there, I wasn't sure they gave me a deal or not but but after looking at their retail pricing, it looks like they did give me a deal + there was a $70 rebate that ended that day.
But my bootie is still hurting.
Jusseth
Sep 13, 2020 12:25 PM
teamghost
Jul 28, 2015 04:52 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
ZacDesu
Jul 14, 2015 11:13 PM
