Yokohama Avid W4S
I had these put on my Z. Then I put 11,000 miles on it and traded it on. The dealership asked me if the tires were new. I could have easily gotten 20 - 25k miles out of them on a Z ... somethings obviously wrong with your alignment. My personal favorites as far as tires go were the Bridgestone Potenzas I ran on my Maxima, those things stuck like glue!
I had my alignment checked today. It was off very little, but the shop put it back into alignment. The springs/shocks/swaybars all checked out fine. The shop said being off the amount it was shouldn't of worn the tires down. However, I did pass state inspection with the tires on the car. I am wondering if there was a defect with the tires I bought so I am awainting a response from Tire Rack and or Yokohma. Thanks for all your input.
^ surprising. from those pics it certainly looked like either the alignment was WAY off, or you had worn suspension parts. you must drive very aggressively - i'm thinking donuts? your fronts look fine so it doesn't look like wear from cornering. curious...i doubt it is tire defect since they are both affected.
