How to tell bearing noise from tire noise?
Old Feb 23, 2009 | 04:27 PM
evolver's Avatar
What is a good way to differentiate bearing noise from tire noise? I Toyo T1Rs on all four corners. They have about 13K miles on them. I hear some noise in two speed ranges, under 20 mph and around 55 mph. At high speed, other noises prevail. In 0-20 range, I also feel very light but high-frequency vibration on the steering wheel.
Does it sound more like tires going south or should I be concerned about the bearings?
Old Feb 23, 2009 | 04:58 PM
kenchan's Avatar
bearing noise sounds like an errie engine noise of a DC10 and
will continue to get louder as you increase in speed.
Old Feb 23, 2009 | 09:24 PM
bocatrip's Avatar
Considering that all the Coupes are loaded with tire issues that cause road roar...bearings are very rarely a problem.
Old Feb 23, 2009 | 11:57 PM
DTM's Avatar
DTM
If it is the bearings I think the center of your wheel will be a lot hotter then the outer part. At least that is how it was on one of my old cars.
Old Feb 24, 2009 | 01:19 AM
GR8NISS's Avatar
I had a bearing gone bad on my 3rd generation maxima, and let me tell you, that thing sounded like the whole car was going to fall apart.
Old Feb 24, 2009 | 02:02 PM
Q45tech's Avatar
You put car on lift spin tires by hand [rears with engine] and listen to [each] bearings with a $3.99 stethoscope.
http://www.northerntool.com/webapp/w..._385487_385487
A more expensive alternative is to buy 4 new tires and mount them.
Noisewise most non Michelin tires are done by 8,000 miles.
Old Feb 24, 2009 | 05:21 PM
bocatrip's Avatar
I was wondering if that stethoscope is at all practical for finding interior rattles or just engine and trans noises?
Old Mar 5, 2009 | 06:02 PM
evolver's Avatar
Thanks for the hints! I especially like the stethoscope approach
I'm pretty positive now that it is the tires.
Old Mar 5, 2009 | 06:25 PM
nghiars's Avatar
i think it may be the tires... im on t1rs with about 10k and they make that vibration at about 20 mph as well.
Old Mar 7, 2009 | 06:33 AM
Infiniti Chica's Avatar
A bad bearing will sound like a roar, whine or growling, and at higher speeds, it will be a louder whining noise. To test them. grab the tire at the top and push/pull it several times in rapid succession. You'll often notice mild play or a clicking sound. Bad bearings often get lose and allow for the wheel to click from side to side. By the way, once you have this, the bearings are shot-- don't drive it anywhere but to the shop, and go slowly!
Tire sounds usually are hums that get louder the faster you go, thumps (if you have a flat spot), some mild low sounding whirring or squeling if tires have extreme toe-in or toe-out.
Stethoscope is also a good way-- I've used it to hunt down sounds that travel from one side of the car to the other.
Good Luck
Old Mar 7, 2009 | 04:58 PM
bocatrip's Avatar
mechanics stethoscope
Great deal! I just got one and I can't believe the price! It seems pretty sensitive as well. I'll update when I use it.
Old Mar 18, 2009 | 12:58 PM
dgg3535's Avatar
I thought I had the typical tire roar with the front tires on my 05 G35 (45K)also, but it was a bearing. When I would slow down it would howl, turn to the left it would howl , but turn to the right it was quiet. Dealer said they change out a lot because of hitting potholes with the short sidewall 19's.
Old Mar 18, 2009 | 01:18 PM
KSWAY's Avatar
Do this....<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/JSsC-lWB1lg&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/JSsC-lWB1lg&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
rezendvous420
May 31, 2020 01:26 PM
ScraggleRock
Aug 11, 2015 10:16 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
rping
Jul 26, 2015 09:53 PM
Thaaa_king
Jul 18, 2015 05:56 PM
