Offset help
Old Mar 10, 2009 | 12:18 AM
skahide's Avatar
Offset help
I have a 04 coupe with the stock 17's. Bought some rare rims very cheap and need to know what spacer size to get for an aggressive stance. The new rims are:
FRONT: 17x8.5 (+43)
REAR: 17x10 (+38)
PLEASE, I KNOW THEY ARE 17'S, I DON'T WANT TO HEAR OPINIONS ABOUT RIMS, JUST OFFSET HELP.
I have yet to drop it, but do want to once i get the stance.
Thanks.
Old Mar 10, 2009 | 12:24 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
30 up front 25 in the rear.
-GP-
Old Mar 10, 2009 | 12:27 AM
skahide's Avatar
Will that put it even with fender or will it tuck it (enough to put a 1" or more drop)? thanks
Old Mar 10, 2009 | 12:33 AM
When you drop the car, the suspension will naturally camber inwards, so unless you want to correct the camber, then you'll be fine. What size are the tires?
-GP-
Old Mar 10, 2009 | 12:35 AM
skahide's Avatar
For now the ones that came on them.
Front: 245/45/ZR17
Rear: 275/40/ZR17
Will change the size once they need to be replaced.
Old Mar 10, 2009 | 12:37 AM
what size are you changing to?
-GP-
Old Mar 10, 2009 | 12:38 AM
skahide's Avatar
No idea. widest i can get them. they are quite new so i havent thought that far along
Old Mar 10, 2009 | 12:42 AM
30 front 25 rear and roll your rear fenders once the car is dropped.
-GP-
Old Mar 10, 2009 | 12:43 AM
skahide's Avatar
Since im new to wheels and tires what size tires would you recommend?
Old Mar 10, 2009 | 12:46 AM
The sizes you have on now are good for the coupe. If you want, you can do a 285/40 in the rear, that's the widest i'd go. The 245/45 front is a good size for an 8.5
If you decide to put a 285 on the rear, then i'd go with 20mm spacers out back just to be safe.
-GP-
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
