Bought 4 new tires, dealer messed up installing them?
Old Apr 29, 2009 | 10:41 AM
FuriousG's Avatar
Angry Bought 4 new tires, dealer messed up installing them?
Hey all, how is it going? I bought 4 new Conti tires, dealer installed, rims were scratched up so they send them off to a wheel specialist. How can I verify if they installed the tires correctly to the correct sized wheels after the powercoating? This is why: I read on here the 17" rims fronts and rears are different sizes. The tires for front are 225/50/17, rear 235/50/17. Wheel specialist probably took off all 4 new tires and baked the rims.
Could they messed up and install 235/50/17 on the front-sized RIMS, and 225/50/17 to the REAR-sized wheels after this powercoating process? Anyway to verify this w/out popping back to dealer. Thanks.
-03 Coupe Auto 17" OEM stocks
Old Apr 29, 2009 | 10:52 AM
vjquan's Avatar
Physically they shouldn't be able to as the front has a pin/bolt that prevents the rears from being put on the front unless they removed that pin. Also, if you have been observant enough, the rims themselves look a little different. The rears have more of a curve or dish (for lack of a better term) than the fronts do. If you can't discern the difference, you can also put an inspection mirror behind the spokes as they have the size stamped on them. Fronts are 7.5", rears 8"
Old Apr 29, 2009 | 10:53 AM
uf20wop's Avatar
go out and look on the side of the tires?
Old Apr 29, 2009 | 10:55 AM
G35fromPA's Avatar
17" coupe wheels are the same width front and rear, 7.5", so it's not an issue to worry about.
Old Apr 29, 2009 | 10:57 AM
vjquan's Avatar
Negative - 7.5" front, 8" rear.
Old Apr 29, 2009 | 10:58 AM
FuriousG's Avatar
I thought they were different. I haven't looked at them, just got them back. The guy powercoated the front face and the walls of the rims. So the stamped size probably got covered.
Old Apr 29, 2009 | 11:00 AM
vjquan's Avatar
Stamped size is on REAR side of spokes. Also, maybe not stamped, but raised.
Old Apr 29, 2009 | 01:42 PM
FuriousG's Avatar
Thanks all. I will look at the behind the wheel when I get a chance to this week.
Old Apr 29, 2009 | 02:32 PM
bocatrip's Avatar
Correct 7.5"front, 8" rear. The 18s are 8 in front and rear.
Old Apr 29, 2009 | 03:02 PM
G35fromPA's Avatar
Oops...my bad. I misread the specs chart on Infinitihelp.com...
chinee
Jun 10, 2024 07:48 PM
ghost_g35
Aug 7, 2015 10:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
itschuckster
Jul 25, 2015 08:07 AM
