Hello all from Tire Rack
#196
Neal,
I have a 09 G37 6MT S 18"
Fr: 225/50R18
Rr: 245/45R18
Hotchkis sway bars
Fr Setting: Only one hole
Rr Setting: Middle hole (3 holes)
I replaced the rear stock RE050 tires with BS RE960s from tirerack. I know that it is bad to mix tires but i'm waiting for the fronts to wear out. The car seems overly sensitive when cornering or swerving side to side. Is that b/c the tread patterns are different? Will the car stabilize if I also get RE960s in the front?
I was told that I could get 235/50R18 and 255/45R18s instead of the stock tires. I don't see any tire out there that has a stiffer sidewall than the RE050 in stock sizes. If I go outside of the stock sizes, I can get the Michelin pilot sport A/S, which I know has a stiffer sidewall. I'm going to increase the psi on the rear tires and stiffen up the rear sway bar to see if that helps. Thanks for your input.
Fr: 225/50R18
Rr: 245/45R18
Hotchkis sway bars
#197
I had my Eibach sways in the same position as yours and had no issues. I'm quite certain the mixed summer/all season combo on the car is what's causing the issue. Differ designs, compounds, tread depths, etc making the car work against itself from front to back. Like walking around with a dress shoe on one foot and a work boot on the other. Can get around.... just not that efficiently.
#198
neal hey bro i need some help on tires for my truck
its a 1990 chevy 6cyl 1500. Its the limited edition SPORT with the 5 speed. Its in storage right now so i cant look at the tire wall to get the tire size but alot of the forums say it uses the same tires as the 454SS. I googled pics of the 454SS and the wheels look the same but i dont want to make a mistake and buy the wrong tires. Also looking for a drop so if you can help me on the suspension parts needed id apreciate it. Looking to buy atleast two tires next thursday and the other two and my drop parts the following pay period.
#199
#200
#201
#203
Site says the Conti DWS but I don't think they will live up to the hype... and they wont be in stock in less than 6-8 weeks.
I'd also look at the Michelin A/S+ and new Yoko Envigor. Both are great performers for year round driving. Michelin a bit more sport based, Yoko a little more mileage.
#204
#206
Hi Neal,
I have some g37s wheels with the following specs:
f 19x8.5 +43mm r 19x9 +45mm
I'm looking to run the following tire setup on my 05 sedan (stock height) but I havent seen hardly anybody who is running this on this site or any of the other related sites (idk if my searching ability is terrible or what):
f 245/40/19 r 265/35/19
is this setup known to cause problems or is there a reason 265/35/19 arent very popular for the back? thanks, appreciate your input.
#207
#208
Hey neal I'm driving an 05 coupe with 19 inch tires, Needing to buy something new. Looking at the Continental ExtremeContact DWS but there seems to be alot of mixed reviews on them. Also alot of the reviews most of the tires say "for the price the range".
Whats your opionin on those tires and what would recomend?
Look foward to hearing back from ya.
Josh.
Josh.
#209
Sort of mixed myself on those. In a nutshell.... great tire for the $. Above average across the board, better than Kumho's/Sumitomo's, maybe better than the Pirelli's. Do I think it will stay #1 on the list....no.
I predict it will stay #1 in its class until they come into stock and more people have them on the car to review. Original Extreme Contact did the same when it launched. Handful of people got them, loved it for the first few thousand miles, then went on horrible b/o for 3-4 months, then fell in the ratings. Initial buzz wore off after about a year.
Not a bad tire at all, but not a tire worthy of a #1 ranking. It is better than the original, however. If you don't drive super aggressive and want a tire that does a little of everything then it will work out great.
#210
Thanks, right now I'm trying to decided between Nitto NTO5's or Hankook Ventus V12 evo K110. However atm I got slammed with a bunch of bills so new tires may have to wait until the end of the month.
