Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
  #1681
Old 03-30-2011 | 02:04 AM
4DGS's Avatar
All stretches are streetable dude.
If you look at the spec sheets for LXZ, it actually gives you all your brake clearances.
If I recall, WS-Lo is high brake clearance and the other is minimal brake clearance.
You could run 20x10 +6 and 20x11 +6.
Your car will be able to handle a 10mm spacer easily front and back and that will definitely give you a nice clean amount of poke and you can retain stock body.
Tires I'd say 235/35 front and 255/35 rear.
  #1682
Old 03-30-2011 | 09:46 AM
05Scoobyroo's Avatar
I have on order a set of TSW Snettertons that are 20x8.5 +20 Front and 20x10.0 +25 in the rear. I'm dropped on Tanabe Sustec Coils (non-adjustable damper) with OEM Brembos. I'm not looking to go completly flush, I just do not want the sunken in look. In addition, I'm trying to avoid having the sidewalls of the tires sitting at a 90 degree angle or buldging as I'm not a fan of that look. What tire size do you recommend for the fronts and the rear? Would I need spacers on these offsets?
  #1683
Old 03-30-2011 | 12:23 PM
P10 WRC's Avatar
hello guys. I found a good deal on some Black SSr Professor Sp1's and need some advice. I have an 06 OB 6mt Sedan lowered on 350z s techs. The specs for the wheels are as follows
Rear: 19x10 +37 w/ huge tires that i won't use
Front: 19x9 +31 w/ new 255/35/19 that i would probably swap to the rear wheels instead or keep on the front.
Would a 255/35 look dumb on a 10 inch wheel in the rear if i'm not slammed?
edit: what size tire should i run up front if i decide to put the 255's out back? Also, I don't think i will need any fender work as i am not slammed, but let me know if i do.
Thanks,
Marty
  #1684
Old 03-30-2011 | 04:37 PM
4DGS's Avatar
I'd go 10mm spacer front and back.
Are you saying you want to stretch the tires? Or you just don't want them over hanging the lip of the wheel?
Ideal setup would be 245/35 and 265/35 But you could run 235/35 and 255/35 if you don't want the wheel to have a broad shoulder. Depends on the tire as well though... Let me know and I'll lend you a hand.
The guy is asking $1600 and they are in great shape. Is that too much to pay? Would a 255/35 look dumb on a 10 inch wheel in the rear if i'm not slammed?
here is a pic of one of the wheels
Marty
Marty, buy those immediately. That is a retarded deal, those wheels are worth about $1100 a piece.
You can run the 255/35 on the back no problem and not look weird at all, Then put a 235/35 up front. I would suggest going lower than you are for that tire size but it's not necessary.
BUY THEM.
  #1685
Old 03-30-2011 | 04:47 PM
P10 WRC's Avatar
thanks a bunch man, i will but them asap.
  #1686
Old 03-30-2011 | 05:05 PM
4DGS's Avatar
PReeemo.
You should also buy some coilovers car will be super sick with those wheels.
  #1687
Old 03-30-2011 | 07:32 PM
P10 WRC's Avatar
yeah i will save up for some coils and rear toe bolts/camber kits. then i will slam it and go flush with spacers and fender work with the wheels for a semi aggressive look.
would i need any fender work on the rear with the 10 +37 and the 255/35 tires?
  #1688
Old 03-30-2011 | 08:16 PM
4DGS's Avatar
Nope
  #1689
Old 03-30-2011 | 10:13 PM
the_sedan's Avatar
thanks 4dgs. ever decide on those lights? still got them sittin in my front porch. lol
and i meant streetable as in a nice stretch, but no barrel lol. i like my 245/35 on a 10 stretch. the fronts are ever so mild with 225/35 on a 8.5 lol.
i saw their chart but it just started giving me a headache. haha. wonder how the numbers would change if i did the akebono swap.
  #1690
Old 03-30-2011 | 11:22 PM
4DGS's Avatar
Still on the fence about them lol so much **** going on with my car at the moment.
Yea their charts always suck.
With 15mm spacers and the specs I mentioned you won't have any problem clearing Akebonos.
the 235/255 stager is nice, slightly more than what you have now, but not retarded. Looks like you're running FKs? don't they run small and bubble. Buy those sizes in General UHP and they will run slightly larger, last longer and stretch better.
  #1691
Old 03-30-2011 | 11:41 PM
the_sedan's Avatar
nankangs up front and dunlop sp sigs in the back. and i agree, the 235/255 stagger is ideal for me. yeah the chart is a lil confusin for me and i didnt know what ws-lo and all that jizz meant exactly. i saw width and offsets lol. just lmk bout the lights cuz i was gonna trash em if u didnt want them.
  #1692
Old 04-01-2011 | 01:48 PM
P10 WRC's Avatar
BUY THEM.
The 255's that are on the wheels now are BFGoodrich g-force T/A KDW. Should i buy the same brand for the front 235s? Also, what lugs should i consider, or is that not really an issue?
Also, if i wanted to go flush, what size spacer should i use or is there a chart or something i can reference?
  #1693
Old 04-01-2011 | 08:37 PM
4DGS's Avatar
Don't have to buy the same tires, BFGs are expensive as hell.
Just make sure the tire runs similar to the BFG (small true or large)
Here's a list of tries that run large just like the Gforce.
* Continental Contisport
* BF Goodrich g-Force KDW
* General UHP
* Bridgestone S03
* Kumho SPT
* Federal ss595
* Pirelli P-Zero Line
* Goodyear F1 Line
* Cooper Zeon 2XS
* Kumho Ecsta Supra 712
* Vredestein Ultrac Sessanta
* Proxes T1R
* Wanli S-1099
* Nitto Invo
* Wanli S-1088
* Marshall Power Racer
* Kumho Ecsta AST
You'll be pretty flush with those offsets, hence why I told you to hop on them quick.
If you want to poke though, you'll need 20mm spacers and different tires (and coils to pull off the look)
But to be flush, you'll probably be happy with where they are and maybe add a 5 or 10mm later on down the road.
  #1694
Old 04-03-2011 | 05:27 AM
geegeegee's Avatar
If I were to powdercoat my rims with a lot of curb rash, would that fix the majority of the curb rash, or will it only change the color?
  #1695
Old 04-03-2011 | 10:16 AM
9tray turbo's Avatar
plan on ordering Varrstoen 1.1.2 for my coupe 19x9.5 f/19x10.5 r, +0 offset all around. What tire sizes should I run?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
