Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#3181
Gonna bust a noob and ask this... I've heard 19x8.5,9.5 is good for performance and 19x9.5, 10.5 is good for looks. What about 19x8.5 +23, 10.5 +24 . Might pull the trigger on some volks and just wanna get some more info. My first time dealing with non stock-ish wheels.
Also looking to use 245/45 on the front and 275/40 on the back. Would those be ok on my my stock fenders? Ill be dealing with a drop later. Im on F&F Type II but getting ready to sell them
#3182
ok here is my question...new to this.
i have a 2003 g35 coupe with stock 17"s/stock brake system ....i want to buy these 2011 g37 19"x8.5" in front and 19"x9" in the rear...how can i make this happen...tire size i need? spacers? best way to make these fit and not messing up the handling to much...open to all suggestions. thanks
pm's also if your in north nj area and can install this set up if you i buy what i need
#3183
You mentioned natural camber...are you not planning to run camber arms at all?
Last edited by DrewDrew; 04-12-2012 at 03:06 AM. Reason: mispelled your name Blain. sorry. hah
TGMcCoy (04-12-2012)
#3184
Nope. It'll fit great. No worries about the front. You'll need -2.1* in the front, -2.5* in the rear - just so there's no surprises. I would run 235/255 because of easier tire sizes [as opposed to 245/35 and 265/35(not a real popular size) or 275/30, etc). I think Blaine prefers running the same sidewall ratios as well because it keeps the stretch the same.
Thanks again!
#3185
Well, how much did you want to lower? Each inch will provide -1.5* camber. So, it won't look as flush as you might want - for example, drop it 2", which relatively isn't much at all, and your wheel lip will already be on the closer side of "inside" your fender at about -3* camber.
I would get camber kits - and since I'm not the greatest with perfect offsets and natural camber, I'll let Blain handle that one.
#3186
Those will be fine though as for the tires you'll want something smaller.
Probably 245/40 and 275/35 or 245/35 and 275/30.
Easy way around that is drop two tread widths, 225/35 and 245/30 stretch very similar.
DrewDrew (04-12-2012)
#3187
Sorry, I'll repost my question. I don't want to confuse anyone who's either read my question and didnt know i had a sedan, or for those with similar questions as mine:
2005 G35 Sedan
20x8.5 +40 up front, 20x9.5 +45 out back. Tire sizes are 245/35/20, 255/35/20. I have two sets of spacers: 20mm and 25mm NOT installed. I haven't installed them because I'm lazy to install my camber kit. But I Finally got around to installing rear camber arms, toe bolts and A-arms out front. If I plan on running the spacers, which set should I install where, and at what camber settings? Or would I be better off simply running 20mm spacers all around, thereby giving my wheels a new offset of +20 and +25?
2005 G35 Sedan
#3189
#3190
2005 G35 Sedan
2005 G35 Sedan
The rear can handle the 20 or even a 25mm with a good roll and a about 3 degrees of negative camber.
I'd say just test fit and see where they sit, you have them in hand so it's not a big deal. The amount of camber and the way they fit is really up to you and you're not going to have any issues MAKING them fit.
This is 5mm more aggressive, but with around -3.5 degrees, a minor pull and 235/35
#3191
If that is more aggressize that the 19x10.5 +24 I will be fine. If I run a 245 series tire like you said previoulsy I think it will be exactly what I am looking for. I am a fan of aggressive Just didnt want so much poke and stretch that it loses practicality I drive my car almost everyday especially in the summer. I already run about -3 degrees of camber so with a fender roll (like you said) and raising my car up a little the fitment should be what I am looking for. Im gonna try them out.....Thanks for all the info, the help and picture...I'd be clueless without this thread.
#3194
Getting air and 1/4s sprayed in the nest couples weeks
#3195
Nope. It'll fit great. No worries about the front. You'll need -2.1* in the front, -2.5* in the rear - just so there's no surprises. I would run 235/255 because of easier tire sizes [as opposed to 245/35 and 265/35(not a real popular size) or 275/30, etc). I think Blain prefers running the same sidewall ratios as well because it keeps the stretch the same.
Blain, have any input on these specs, natural camber, offsets? I know i've been asking alot of fitment questions the last few days... gotta get some wheels soon!
