Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#3136
yea I'm not sure if I can pull anymore on the rear, when using the roller we had to stack more spacers to flare it out more. Here are a few pics from my FS thread:
I can actually tuck in more if I put my toe links on and adjust for more camber. just using these til I finalize my track setup and street shoes.
Maybe I can get away with 11s in the rear, but nonetheless i don't mind the bulge since it'll be a track setup.
#3137
#3138
#3139
#3140
#3144
your roads must be so much better in...wherever you are, than in OK. And what difference is 650lbs springs from the ones you had originally? You are static...meaning?
#3146
Ha, in that case I was ecstatic about being static...until I felt every little bump and started to bottom out. Roads here are WACK! Had to raise my G and put OEM wheels...so sad!!!
#3147
#3149
