Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Apr 23, 2011 | 01:49 AM
  #1771
trickdeez's Avatar
I have an 05 coupe and I have the same question like Salams, RS-8 20x8.5 offsets 18 and 20x10 offsets 20. I'll be dropped on Eibach Sportline with spc camber kit front and rear. What tire size do you guys recommend and will I need fender rolling? Also, will I have to have negative camber for these things to clear? I'm a newb to all this stuff so I would appreciate the help.
Old Apr 23, 2011 | 02:05 AM
  #1772
4D05G35's Avatar
Originally Posted by Byteman
Hi guys,
2007 G35 Sedan base; everything stock
stock wheels/tires
17 X 7.5 +45 225/55/17 all around
planning to run
18 X 8 +45 245/245/18 all around
rims-tires calculator says
* Package is 10 mm (0.4'') closer to suspension/brakes components. Acceptable for most cars.
* Package will stick out 10 mm (0.4'') farther. Acceptable for most cars.
Would I rub anywhere? or would set up work without any issues?
Thanks!
Yes that set-up will work without issues. You can go with an even lower offset (+25-30) if you want the wheels to sit a little more flush. +45 they will still be tucked in like the factory wheels.
Old Apr 23, 2011 | 09:59 AM
  #1773
zdendaas's Avatar
03 coupe with brembo question
Thinking about making a trade on C/L for some konig crosshairs 8.5 front with 245/35/19 tires and 9.5 rear with 275/35/19 tires. offset is 40. Should these wheels fit the car decently and fit over the brakes? here is a link to the post on C/L. ( http://milwaukee.craigslist.org/pts/2336558630.html )
Old Apr 23, 2011 | 11:42 AM
  #1774
deathdank420's Avatar
If it doesnt clear the brembos just buy some spacers I think they will tho, funny I was just looking at that posting this morning. You from Milwaukee?
Old Apr 23, 2011 | 11:50 AM
  #1775
19x10" noob question
can I run 245/40/19 tires on a 10" wide wheel?
The tire says its rated for up to 9.5" wide, will the tire just stretch and be ok or will it be too much of a stretch?
sorry for the noob *** question.
Old Apr 23, 2011 | 12:10 PM
  #1776
zdendaas's Avatar
Yeah, I live on the Eastside.
Old Apr 23, 2011 | 02:43 PM
  #1777
Byteman's Avatar
Thumbs up
Great ... thanks for your reply, 4D05G35!.
Old Apr 23, 2011 | 03:12 PM
  #1778
salamsg35's Avatar
Smile
Originally Posted by geegeegee
No, I don't rub at all.
There's still a slight fender gap, but it's bearable. I just wanna drop it on htechs but don't know if I'll be rubbing after that...
Here are some pics of how they sit on my car. https://g35driver.com/forums/members...bums-baby.html
thx man for the info.. you car look nice, it would be nicer if you droped it i can see that.
Old Apr 23, 2011 | 04:58 PM
  #1779
boostedforlife's Avatar
05 Sedan Droped 1.6 on rsr, Rear Fenders rolled.
I have three rim options,
18x9.5 +20 ALl around 245/40 in front and 285 35 in rear,
18x9.5 +38 all around 245/40 front 285/35 rear
18x9.5 +38 front 245/40 and 18x9.5 +20 Rear 285/35
I dont want to run more than neg 2.5 camber. Which set up would work with out rubbing?
Also which would look better?
I also have brembos but I dont think that should be a problem.
Old Apr 23, 2011 | 06:24 PM
  #1780
4D05G35's Avatar
I dont think that you will be able to get a 285/35 in the rear with 9.5 +20, The +38 should work. I am just judging by my set-up. I have 20x10 +25 which is almost exactly the same (as far as extending out) and the widest I can go is 255/35.
Check out this thread to get some visuals.
https://g35driver.com/forums/media-s...tch-sedan.html
Old Apr 23, 2011 | 10:52 PM
  #1781
Thanks for the update, I checked through a good chunk, I found one other guy with the same rims, but he was only running 235's. I couldn't seem to find anyone rollin thick.
Also since the rim offset is 38 instead of 20, that means it will be less concave right?
Old Apr 24, 2011 | 03:10 AM
  #1782
4D05G35's Avatar
Yeah usually higher the offset the less concave the wheel is, but wheel design will play a factor in that too.
Old Apr 24, 2011 | 03:23 PM
  #1783
geegeegee's Avatar
I have 20/8.5F/10R on my 06 G35 Coupe. Tire sizes are 245/35 in the front/ 275/30 in the rear. Offsets are 25FR. My question is...if I decide to drop it on 350z H Techs, will I be rubbing? Would I need my fenders rolled?
Thanks
Can someone answer this? D:
Old Apr 24, 2011 | 04:18 PM
  #1784
4D05G35's Avatar
I am a little more up to speed on sedan offsets, but I do believe that you will be ok.
I dont think that you will need to roll your fenders. I know a lot of people run 10.5's with 275's/285's in the rear with high teen/low 20mm offsets just fine.
Old Apr 25, 2011 | 04:32 PM
  #1785
boobie12's Avatar
kinda new with rims dnt know much so dnt bash me guys lol,but if i get piaa rozzas 18 with a offset of 35 with they fit a g35 coupe fine right?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
