Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
  #1786
Old 04-25-2011, 10:34 PM
4D05G35's Avatar
Originally Posted by boobie12
kinda new with rims dnt know much so dnt bash me guys lol,but if i get piaa rozzas 18 with a offset of 35 with they fit a g35 coupe fine right?
How wide are the wheels?
A quick search looks like 8" - 9" wide.
If thats the case I would look for other wheels or purchase some large spacers.
  #1787
Old 04-26-2011, 05:35 PM
d0nutboii's Avatar
tires sizess
i have an 03 5at sedan and recently got coupe 19s. i know some people prefer 225/40f and 255/35r but what is the correct tire size to go for?
thanks in advance.
  #1788
Old 04-26-2011, 06:44 PM
tasi's Avatar
G35 sedan 06
Hi
I have 9x19 and 10x19 ET24 on all.
will they fit a 06 G35 sedan.
I dont want them to stick out of fender, more like flush.
I want 0 camber.
if yes, what is max tiresize?
many thanx
  #1789
Old 04-26-2011, 07:02 PM
qbanboy's Avatar
hey guys whats good i just got my G and i'm trying to figure out what kind of rims should i put. I do want to lowered with the S-tech teins 1.2 front and 0.9 rear. My questions is after i do this which rims size and offset should i get between these two?
I have two options for the same rim
FRONT
20x8.5 with 35 offset
20x9 with 20 offset
REAR
20x10 with a 35 offset
20X10.5 with a 30 offset
I would like to have a HUGE lip in the back but no any stretch tires or fender rolling. so please give me some suggestions....
http://www.elementwheels.com/prodima...nidriftblk.jpg
  #1790
Old 04-26-2011, 07:04 PM
sk8bo4rdv's Avatar
FRONT
20x9 with 20 offset
REAR
go with the 20x9 +20 and 20x10.5 +30. u wont need to roll ur fenders or stretch ur tires with those weak offsets
  #1791
Old 04-26-2011, 07:07 PM
qbanboy's Avatar
ill right man thanks so you think that the 20x10.5 with the 30 offset will have more lip than the 20x10 with the 35 offset?
  #1792
Old 04-26-2011, 07:10 PM
sk8bo4rdv's Avatar
yea u always want to go w/ the wider wheel .
get the sizes i said earlier and slap on a 245/35/20 front and a 275/35/20 rear and u should be set. no fender rolling needed or stretch.
  #1793
Old 04-26-2011, 07:37 PM
qbanboy's Avatar
alright thanks a lot for your help....
  #1794
Old 04-26-2011, 08:27 PM
boobie12's Avatar
yea there 18x8.5 and is anything wrong with that im getting them for a great price
  #1795
Old 04-26-2011, 10:01 PM
grego9198's Avatar
I'm picking up a 2004 G35 sedan this weekend and want to pick up some new wheels. I've been reading these forums the last few days to try and understand what will fit my car, but I'm still a bit unclear to what will fit it properly. It's currently at stock ride height, but am planning on lowering the car a few inches to get rid of the gap.
I'm thinking of picking up XXR 521's 18x8.5 +25 all around. Will I have any issues with these sticking out past the fenders? Or will they be fairly flush? Thoughts?
  #1796
Old 04-27-2011, 12:46 AM
boostedforlife's Avatar
05 Sedan Droped 1.6 on rsr, Rear Fenders rolled.
So I Narrowed it down to the
18x9.5 +38 all around 245/40 front 285/35 rear
will the front have enough clearance on the inside to not hit the upper control arm, or whatever bar goes up to it? I have been through a few rims and noticed some rubber at that upper a arm.
Would 245/40 front be okay?
255/35 be okay?
TIA
I dont want to run more than neg 2.5 camber. Which set up would work with out rubbing?
Also which would look better?
I also have brembos but I dont think that should be a problem.
  #1797
Old 04-27-2011, 02:06 AM
salamsg35's Avatar
That was helpfull. I'm going with a 20s too almost same setup without rolling fenders. thax
this is the wheel i want, what you guys think??
http://www.google.com/imgres?imgurl=...1t:429,r:3,s:0
  #1798
Old 04-27-2011, 02:35 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
You should be fine with inner clearance. I'd go with a 255/40 up front if you're going 285/35 out back, it will look better with the wide tire out back . The 245 would be a very slight stretch and look funny.
255/35 be okay?
TIA
  #1799
Old 04-27-2011, 02:39 AM
Please don't suggest that people put a 275/35/20 on their G. That's over an inch taller in diameter than stock and not to mention looks like **** with that much sidewall on 20's. The proper rear sizes are 255/35, 275/30, 285/30, and 295/25 for 20" wheels on the G.
  #1800
Old 04-27-2011, 03:25 AM
whoisthis's Avatar
Could some one help me out with tire size?
On my 350z, i have front 225/45/18 on 8" wide stock rims. With my drop, im tucking the sidewall a little bit.
I plan on keeping it tucked. If i go with stretched look in the future like 245/45 or 40/18 on 18x10.5 rims, not completely sure on how much stretch look i'll get from that set up though, what's the prefered side wall height? i sometimes feel like 45 profile looks too beefy on my stock set up.
If i go 40 profile, i need to keep my current ride height. Then i'll lose the hellaflush look.
If i go 45 profile, i can dorp the car .5" more. I'll have more hellaflush look but the sidewall might look too beefy. i can't go 40 profile AND drop .5" because the total drop in height would let me scrape my exhaust flange and get stuck before speedbumps.
what do you think i should do?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
Quick Reply: Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
