Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old May 2, 2011 | 08:55 PM
  #1846
Nightcrawler's Avatar
11 +15 on the rear is nowhere near flush mate - you will be hanging out of the guards like no mans business. 9 +15 on the front is just under flush depending on whether you have a camber kit on.
As for stretch, even a 275 will be stretch like **** on an 11" rim. Do the maths - 11" wide = 275mm bead width. The tyre will look like a trapezium from the rear.
I had a 235 on a 9.5" rim and even that was stretched like hell. FYI most tyre shops here in Australia recommend a 255 on a 9.5" rim, so I would expect them to recommend at least a 300 on an 11" rim.
But hey if you are after the hellaflush look, then you are on the right track (once you put a 15mm spacer on the front)
Old May 2, 2011 | 10:09 PM
  #1847
qbanboy's Avatar
I just found a new treat with these wheels and i may get them since they have a great price and they look damn good...XXR 526
MY QUESTION IS!!!!
OFFSET
WHEELS WIDTH
FITMENT
20x9 +35 or 20x9 +15 FRONT WHEELS
20x11 +15 REAR WHEELS
Now will this fit good on a g35 coupe with a lowering TEIN kit? i would like flush i hate that Mexican look everyone have in they car....i have a g35 no a low ride with gold rays rims and hydrolic suspension...."respect everyone's opinion and point of view"....
Please post what kind of tires i have to run and all others details.....
Old May 2, 2011 | 10:19 PM
  #1848
As I said above 11 +15 will be MEXICAN AS.
9 +35 on the front will be a poor offset, way inside the arches.
9 +15 on the front is perfect flush fitment.
Use this as a guide - 18" 7 spoke 2003 coupe stock wheels are 8" +30, and in my opinion flush at the front you need them 29mm wider, and the rear 40mm wider (if you are lowered and running 4 degrees of camber on the rear, no camber kit on the front).
In my opinion the perfect offset for an 03 coupe is 9.5 +20 front (with 255/40) tyres, 10 +15 rear (with 275/35 tyres).
This website can help you :
http://www.1010tires.com/WheelOffsetCalculator.asp
plug in 8 +30 (if you have a 2003/04 coupe) and use the calculator with your new wheel width and offset. As you will see, 11" +15 is 53mm wider than stock, which is INSANE (and very Mexican - but hey if that is what you like then run with it).
Not sure about over there, but here in Australia you are only legally allowed to run 10mm wider than stock track, which is weak-as offset. But hey, who stays legal?
Old May 2, 2011 | 10:36 PM
  #1849
qbanboy's Avatar
I got your point but then how someone told me if i had a 10.5 +30 i still need spacers to be flush....and i compare both of then and the difference is 21 mm and that is less than an 1' inch....
Old May 2, 2011 | 10:53 PM
  #1850
For the rear 10.5 +30 would need a spacer to be flush - exactly what I said. Using the online calcualtor I linked you to, 10.5 +30 would be 32mm wider than stock, when I told you that you want 40mm wider than stock to sit flush.
As I said above, perfect flush fitment on my V35 2003 coupe is 10 +15 (or equivalent is 10.5 +22) at the rear, running about 4 degrees of camber with camber arms.
Old May 2, 2011 | 11:07 PM
  #1851
qbanboy's Avatar
so 10.5 +22 is equal to 11 +28
Old May 2, 2011 | 11:09 PM
  #1852
qbanboy's Avatar
so if i go with this wheels is going to be at least half inch outside.... correct me if i`m wrong i know an 1 inch equal to 25mm...
Old May 2, 2011 | 11:10 PM
  #1853
Yes, exactly the same.
The extra 0.5" in rim width = 12.5mm = 6.25mm wider each side of the centre/hub. So add 6mm to +22 you get +28!
Old May 2, 2011 | 11:13 PM
  #1854
qbanboy's Avatar
by the way when you say flush is with the fenders roll or not ?
  #1855
qbanboy's Avatar
if is not your wheels are 3/4 of an inch inside
Old May 2, 2011 | 11:14 PM
  #1856
1" does indeed = 25mm.
Not sure what you mean by "going to be at least half an inch outside".
Fact is, that the stock wheels on the rear sit some 40mm inside the guard with a lowered car/4 degree camber kit.
So if you buy wheels that sit 40mm wider than stock track (ie. 11 +28 or 10.5 +22 or 10 +15) they will sit flush with the guards.
Old May 2, 2011 | 11:15 PM
  #1857
qbanboy's Avatar
no i mean with the 20x11 +15 sorry!!
Old May 2, 2011 | 11:18 PM
  #1858
With a little bit of stretch on your tyres you will not need to roll your guards.
I run 245x40 18" tyres on 9.5" +20 rims on the front with flush fitment with no issues.
I run 275x35 18" tyres on 10" +15 rims on the rear with no problems.
If I hit a bump really hard (like pulling into a raised drivewat at a service station) they will have a tiny rub, but no real issues so far. The stock front guards are actually rolled about 45 degrees already, but the reas are dead flat and would be tyre shredders with too wide tyres/wheels and no rolling.
For the relatively small cost, I would recommend you get your guards rolled anyhow if you want to run even mildly agressive wheels for peace of mind. The cost to have all of your guards rolled should be cheaper than replacing one shredded tyre.
Old May 2, 2011 | 11:23 PM
  #1859
qbanboy's Avatar
ok hey if you find any g35 with this wheels post the pic i will like to see how it actually looks, and thanks for the Info bro...
Old May 2, 2011 | 11:25 PM
  #1860
No worries mate.
This webpage will keep you VERY busy and will keep you entertained for HOURS!!!
http://www.rimtuck.com/thumbnails.ph...odel=G35+coupe
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
