Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#2102
I havent looked at it yet, but DJ posted a video about offsets above.
Short answer is. The word offset is just that, it's how far the wheel mounting surface (that mounts to your hub) is offset from the center of the wheel. Example being a 10" wide wheel that has a -0- offset means that 5" of the wheel is on the inside of the mounting surface (hub) and 5" is extending outward. As the offset number increases (say +20) the mounting surface is moved outwards, or offset 20mm towards the outer edge of the wheel. Positive offsets mean that the wheel is tucked in more, negative offsets mean the wheel is pushed out from the center of the wheel. Wheel widths, and offset play a large role in how they fit a particular car.
For example, I have the stock 19" rims on my ride, but the wheels and tires aren't flush with the fender (they're in more). Is there a way to offset the wheels so it's flush?
Oh, and I plan to get the VS-XX rims (19") and I also want them flush. Is there anything I need to know about offsets to get them to look that way?
Sorry, I usually understand things but this is going over my head.
#2103
what do you think about these wheels
I was looking at wheels at Craigslist, I'm just getting tired to spend $50 twice a year to put on my winter/summer tires so I found this ad on CL:
http://denver.craigslist.org/pts/2393539929.html
Should fit my 03 G35 Sedan just fine but will my winter tires 225/55R17 97R fit and what do you think about the wheels? One wheel has a flat spot sounds pretty vague to me. Any input? Thanks
#2104
#2105
#2107
Yea I watched it and I understand what wheel offset is. But what I don't understand is, do you offset the wheel, or does it come with a set offset?
So in your case your wheels are 19x8 +30mm offset and 19x8.5 + 33mm offset.
They are not flush and tucked in a bit. You can add a wheel spacer
http://www.ichibausa.com/whspveii.html
to lower that offset and push the wheel out further. I believe a 25mm wheel spacer is what some use to get the wheels flush to make the wheel offsets +5 and +8. Adding the spacer moves the mounting surface of the wheel closer to the center of the wheel and closer to a -0- offset.
#2109
The wheel comes with a set offset.
So certain rims have a certain offset. That's good to know before buying. Do they ever tell you what offset the rims are? I never noticed. I only see like 19"x9.5 or whatever.
#2110
Here are some pics of a wheel spacer install and pre/post pics
#2111
on
how do you clean volk vs-xx burning black?
aside from soap and water...
the lip is rough when you run your fingers through after cleaning.
can i clean it with clay bar and the liquid that comes with it? how about with water?
i have stock brake pads, dusts are just out of control.
thanks in advance...
#2112
Always ask what the offset is. It sounds like you are wanting a flush fit so ask what the offset is before buying. Wheel manufactures/shops will always error on the side of caution when listing what vehicles their wheels fit.
When they list what vehicles the wheels fit they try to keep the fitment close to OE specs, which as you know is tucked in.
#2113
#2115
ill Sedan
