Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#241
Did some snooping around...
How is it that Most 2pc Work wheels have offset ranged that you can choose from IE+50 ~ -20
Yet all of the 3pc wheels have specific offsets only to choose from.
Wouldnt it be easier to alter the lip size on the 3pc wheel and make it any offset you would like?
#242
Alright guys, I currently have the G37 19" coupe wheels mounted on my 08 sedan lowered on eibach pro-kits, with camber set to about -1.1 to -1.3 degrees all around. The wheel specs for the coupe wheels are 19x8.5 F +43 with 225/45 tires and 19x9 R +45 with 245/40 tires. My stock sport wheels were 18x7.5 F +45 with 225/50 tires and 18x8.5 R +50 with 245/45 tires. I measured between the tire and fender to see what spacer i can install, but couldnt get an accurate measurement. I was hoping to install 20mm rear spacers and 15mm front spacers, is this doable? or is this not possible? Thanks in advance!!
![thewave](https://g35driver.com/forums/images/smilies/th_wave.gif)
#244
Hey guys, just need some help from the fitment guru's on here.
Ok so i got the SF challenges 19x9.5 +28F w/ 245/35 and 19x10.5 +23R w/ 275/35. Question is, i want to get a flush look, im on basics so its lowered, just want to know what kind of spacers i would need to look flush. oh and btw i dont have any camber arms or anything, i just lowerd it w/ tein basics and nothing else.
Thanks in advance.
Thanks in advance.
#245
Thanks in advance.
Thanks in advance.
You can fit +15mm in the front and rear. Just make sure to roll your rear fenders.
#248
#252
#255
on
Ok I'm kinda new at this but i just purchased a set of Venaci V124 20x9.5+20x10.5. I am on stock suspension but was thinking about getting tein s techs to lower the G on. Will i need to roll my fenders? And plus i want an aggressive look so would i be better off putting spacer all around and I'm not sure about what size, any suggestions? Or a Camber kit?
Thanks
Thanks
