Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#392
#393
255/30 on a 9.5 no stretch. if you want a bit of stretch 245/30
285/30 on a 11 a tad bit of stretch
All depending on tire brands
regarding camber: i ran -3 on my rears before and the car was fine. great on corners esp if you dont run too much stretch. as long as the TOE is in spec then you guys are good to go.
#396
heres some parts of the thread i made on our private forum
hope it helps
Heres a list:
SMALL:
- Falken ST115
- Falken ZE-512
- Falken FK451 (D)
- Fuzion ZRi
- Nankang NS-II
- Nitto 555 Extreme
- Michelin Pilot Sport
- Dunlop SP Sport
- Hankook 104
- Hankook v12 K110-->2c's tire
- Hankook v4 H105s
- Toyo T1S
- Toyo Proxy 4
- Yokohama S.Drive
- Avon Tech M500
- Nitto Neo テク Gen
- Ultrac Giugiaro
- Nexen N3000--> Square sidewall
- Continental Contisport
- BF Goodrich g-Force KDW
- General UHP
- Bridgestone S03
- Kumho SPT
- Federal ss595
- Pirelli P-Zero Line
- Goodyear F1 Line
- Falken FK452
- Cooper Zeon 2XS
- Kumho Ecsta Supra 712
- Ultrac Sessanta
- Proxes T1R -->Rounded sidewall
- Wanli S-1099
- Nitto Invo
- Wanli S-1088
For the Hankook ****** out there
In our experience and knowledge:
Nexen N3000 runs Large and Square
Toyo T1R is True but very rounded.
Nitto NT-555 is True
Falken ZE-912 is True but I believe to be more rounded than the FK-452
Sumi HTRZ II and III are True, and the HTRZ III actually stretch pretty well without compromising comfort while maintaining grip.
Bridgestone RE050A run pretty small, and are very rounded. Every Bridgestone in our experience has run very round and skinny.
Hankook depends. But most people will look into K110 and they run pretty true. Not bad at stretching on the K110 and H105s
OFFSET calculator:
#397
is your fenders rolled flat? coz i rolled my fenders flat and i gained a couple of MM.
also you have a bit more meat on your tires so cambering will help.
what brand tires you on?
#398
#400
Beebo also what wheel are you planning on getting, you can pm me if you dont want others to know.
I would say if you want a bit of meat to go with 235/35 20 on a 9.5 and 275/35 20 on a 11
The pad height will depend on if you want to ever run a bbk, do you have brembos?
#401
#402
watch out for bubbles!
yeah adjust dampening and see if it helps with rubbing issues.
is it doesnt just add some camber (just a bit)
#403
some tires runs big some small some are true to size
hope it helps
Heres a list:
SMALL:
OFFSET calculator:
hope it helps
Heres a list:
SMALL:
- Falken ST115
- Falken ZE-512
- Falken FK451 (D)
- Fuzion ZRi
- Nankang NS-II
- Nitto 555 Extreme
- Dunlop SP Sport
- Hankook 104
- Hankook v4 H105s
- Toyo T1S
- Toyo Proxy 4
- Yokohama S.Drive
- Avon Tech M500
- Nitto Neo テク Gen
- Ultrac Giugiaro
- General UHP
- Bridgestone S03
- Kumho SPT
- Federal ss595
- Goodyear F1 Line
- Falken FK452
- Cooper Zeon 2XS
- Ultrac Sessanta
- Wanli S-1099
- Nitto Invo
- Wanli S-1088
OFFSET calculator:
i do want meaty tires since the roads here suck
ill pull and do a flat roll if that what it takes
will i need like -2 or -3 camber?
#404
Whatcha mean? I've had no issues with em so far. Stretch looks good Is there a better tire i can use for the rears that'll give me this same stretch look and performance?
#405
G37 coupe, non-sport hub vs I35 hub
Just got a set of the G37 coupe non-sport 18s. Went to put them on my 2001 i30 (they will be replacing the i35 17s I have on the car now), and noticed that the new wheels seemed to be a little "shakier" as I was installing them. Almost like they wouldnt line up flat with the brake rotor. I dont have the special lugs (didnt realize that until now!) so I couldnt tighten them down, but just trying to line them up by hand it didnt seem like I could make them flat while just holding them there.
My question is why this would happen?
My first guess is the hub size, but it seems to be the same as my i35 wheels.
Any ideas?
Thanks in advance.
-Chris
Any ideas?
Thanks in advance.
-Chris
