Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#333
hey shane, i know you do fender service. do you do pulls and flat rolls like what skaterbasist said below?
what are you dropped on? i'm only dropped on GF210's.
initially wanted falkens, but going with kumhos now.
#334
#335
#336
well it all depends on what width the wheels are, i would get a 225/35 on a 9.5 as opposed to a 245/30, if i had like a 10.5 up front i probably would do a 245/30 or a 35 series, same goes for the rear, an 11.5 on a 255/35 would be a nice stretch and for a 275/30 you would need like a 12.5 or 12
#340
Whats up guys, pickin up a set of work t1s +7 r disc front n +0 o disc rear... Got spc cambers in rear nuttin in front, gonna roll the fenders, runnin mild stretch tires. 225/35/20front 255/35/20rear.. Dropped on flex coils.. Should I get the alignment back to oem spec? I dont want the fenders to rub so would i be safer to roll AND pull out fenders? Wanna go to more wider tires since im not that big of a fan of a stretch so im thinkin ill needa pull em out. Thanks for ur help guys
#342
#343
lips will show on those tires
also your offsets needs a bit of stretch tires to fit
with a +7 you can probably get away with a 235/35? it will also match the 255/35.
heres some examples of my set up:
255/30
285/30 BFG KDW
20x9.5 +18
-1.75?
20x10.5 +9
-3.5 camber slight rubbing driver side
Current:
fronts
225/35-2
-2.35
245/35 -1
coils are a bit compressed to check clearance.
around 5mm clearance or less i think? no rubbing and i rolled the fenders as flat as i can
-3 camber if i recall
Also you need to drop the car or LULz
#345
Yes i can!
