Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
  #346
Old 10-14-2009, 05:30 PM
elperuano's Avatar
wow, sick.. well what i meant to say was im not a fan of stretched tires and i recently purchased these wheels wit the tires it had on em. So for now im gonna ride em out til i needa replace em.. Currently on stock 19s n just had the alignment put back to spec after puttin an spc camber to oem spec.. Wit my new setup which will be put on today off 225/35/20 front no camber n 255/35/20 rear spc camber at oem spec i dont think i'll rub, gonna have the fenders rolled.. What "I" would like to do once tires need to be repaired is run a lil wider tires... What would be a better set-up of tires to run so that i wont have tire rubbing issue? I'm slammed on teins.. Not very knowledgeable on cambers n what they should be set on I've always had alignments done at goodyear n they always bring it back to oem spec.. I know once i change to wider tires i think im gonna have to flare out the fenders but honestly idk... This is my FIRST set of wheels on my G which i bought like a month n half ago Sick wheels but SICK offset as wheel n i shouldve done my homework.. Thanks for ur input guys.
  #347
Old 10-14-2009, 05:33 PM
ShanesG's Avatar
go 235/265 then i wouldn't go more than that unless you wanna run a fair amount of camber. that will give you a mild stretch.
  #348
Old 10-14-2009, 09:09 PM
elperuano's Avatar
ok thanks shane, well the ride is nice although kinda feels like in the rain my rear end gets loose.. What can i do to correct this? Wheels r on tight camber wit align to oem spec. Should i get the wheels re-balanced? I'll post a pic up tomorrow of it looks sick!
  #349
Old 10-15-2009, 06:29 PM
G U LATER's Avatar
Why does nobody make a 235/35/20 other than Kumho? d
  #350
Old 10-15-2009, 07:17 PM
gtrefever's Avatar
hold on let me ask the tire gods....
  #351
Old 10-15-2009, 09:00 PM
G U LATER's Avatar
don't upset them
  #352
Old 10-16-2009, 12:43 AM
vipers's Avatar
I made a post about this in a thread and I'm doing it here. Sorry but I need the question answered quick cause I am either going to or not going to buy this specific set of wheels. I have a 2004 G coupe...I'm looking at a set of used wheels/tires off a G sedan, they are 18x8, +38 offset. Do I need spacers, rolled fenders? Will they fit? I'm on stock height.
Thanks.
  #353
Old 10-16-2009, 02:45 AM
Dranom's Avatar
^^^get 19s
  #354
Old 10-16-2009, 11:17 AM
vipers's Avatar
Originally Posted by Dranom
^^^get 19s
Can't afford 19's...this is a used set.
Will they fit?
  #355
Old 10-16-2009, 11:25 PM
canucklehead's Avatar
i got my coupe rays on. thanks for the help, guys. these pics are from last weekend.
i paid $680CDN for the set. OEM tires are 99% tread, wheels are MINT! the previous owner drove on them for 4 days, then got a fancy 20" set. he sold his '06 6MT coupe a few weeks ago.
the tires still have the "as-new" ink lettering and rubber ***** on them.
so far no rubbing (3 weeks), and the TPMS have programmed themselves, so no problems there either.
Attached Thumbnails Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::-img_1281.jpg   Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::-img_1284.jpg   Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::-img_1283.jpg   Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::-img_1294.jpg   Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::-img_1296.jpg
  #356
Old 10-17-2009, 01:01 AM
Get_some35's Avatar
^^ if i 0 the camber on the front will i be flush or still need a spacer?
  #357
Old 10-19-2009, 01:20 AM
HXS's Avatar
HXS
HXS is offline
it'll be flush if you zero the camber but your performance is gonna go to sh*t.
just add some spacers... looks like you need at least 15-mm to match the rears.
  #358
Old 10-19-2009, 01:22 AM
gtrefever's Avatar
atleast run some kinda camber id run a 10mm spacer all around like i told you before.
  #359
Old 10-19-2009, 01:42 AM
Get_some35's Avatar
alright thx i just wanted a few more opinions
  #360
Old 10-19-2009, 09:14 AM
vipers's Avatar
QUESTION about my 2004 G coupe
If I use wheels that are 18x8.5 all-around with a +38 offset...but I buy 20mm spacers then the offset would really be +18, right? Would that fit okay? Would it clear brembos?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
Quick Reply: Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
