Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#2716
Xxr 521
Question if these will fit well and what tire sizes I should run. http://www.nlmotoring.com/ProductDet...0142N&CartID=1
XXR 521 18X8.5+25 all around square setup on a 2005 Infiniti g35x sedan NO big brake kit. No mods rite now, but may lower 1.5-2" on Bc racing coilovers in the future. Ordering rims soon for now while looking for input on tire sizes. Please let me know if these are okay to order. Will get spacers around if needed.
Reason I need rims/tires first is because once spring comes I need something to swap my winter setup out 2 as I have no summer setup yet.
Thanks so much =)
Thanks so much =)
#2718
Thanks so much =)
Thanks so much =)
I'd run 245/40 and 225/45
If you want a square set up go 245/40 all around.
The front you're gonna want a hefty spacer so it doesn't look stupid. Probably a 20mm at least. The rears will be good, solid roll and about -4 out back and you should be good.
#2719
Yea you'll be good, I'd recommend a roll in the rear if you do lower it. (even if you don't i still would say roll em)
#2721
Searching and sifting through the majority of this post and I still am unable to find the answer I'm looking for?! ![Dunno](https://g35driver.com/forums/images/smilies/dunno.gif)
Here's what I'm trying to figure out:
06 Sedan with stock suspension and no Brembos
not interested in lowering or rolling
daily driver
20x12 R and 20x10 F?
will they fit without rubbing? (not opposed to using spacers)
what size tires should I run?
Thanks for the help in advance, I've already taken a lot of advice/learned a lot from this forum, so why not add a little bit more knowledge?!
daily driver
![Doh](https://g35driver.com/forums/images/smilies/doh.gif)
#2722
Will these fit??
Just purchased a set of Stern ST8 wheels. They are 20in with 8.5 +20 on the fronts and 9.5 +25 on the rear. The tire size on that is 225/35/20. Want to make sure these will fit with out spacers or fender rolling. I have a 2005 G35 Coupe with the stock 18s and stock suspension. Thanks so much!!
Last edited by NGreeeeeen; 01-02-2012 at 06:20 PM. Reason: Forgot car specs...Stupid me
#2723
question, i'm looking at some 19x8.5 wheels i don't think there available in 9 or 9.5inch widths also i don't want staggered for rotating purposes. The 19x8.5 wheels have a +15 offset. And i'm trying to determine how close to flush they would be, i'm only dropped on Tein S techs 1.75 drop
#2724
Recently got a set of 370z sport wheels. Put them on but decided to take them off cuz they rub to much. But when I tried taking the wheels off they were jammed in and the only way I got them off was by banging the back of the wheels. Tire size are 255/35 front and 285/35 rear any idea why this happened and what do I have to do to make them fit...
#2725
daily driver
Thanks for the help in advance, I've already taken a lot of advice/learned a lot from this forum, so why not add a little bit more knowledge?!![Doh](https://g35driver.com/forums/images/smilies/doh.gif)
daily driver
![Biggthumpup](https://g35driver.com/forums/images/smilies/biggthumpup.gif)
I would recommend a 10mm spacer for this set up.
Also is this a sedan or coupe?
The following 2 users liked this post by 4DGS:
BallerOnaBudget (01-04-2012),
SuperTrooper699 (01-03-2012)
#2726
i recently tried a 370z sport wheel when i had a flat tire on my current wheels and they didnt rub at all with those tire sizes but guess it depends on how low you are compared to me and other factors..
as to the wheel getting "jammed" the same thing happened to me when i realized my lug nuts werent tightening down onto the wheel..the 370 wheel got stuck on my hub and i had to kick the tire to break it loose..
#2730
Tires??
I need to get a new set of tires pretty soon anyway...so for the 20" 8.5 +20, and 9.5 +25 what tire would you recommend for my coupe all stock suspension.
