Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
  #3541
Old 05-25-2012, 06:49 PM
MPG35fiend's Avatar
is 265/30 on a 19x10.5 stretched?
let me re phrase, Will 19x9.5 on 235/35/19 look good with 19x10.5 on 265/30/19????
http://www.miata.net/garage/tirecalc.html
went to this website and its only .01% difference.
PLEASE give some feed back on tire/wheels set up..
btw going with hankook v12s, unless better tires are recommended.
THANKS.
  #3542
Old 05-25-2012, 07:04 PM
DrewDrew's Avatar
Yes it's a stretch. But to get a more similar stretch with the 235/35 on the 9.5, get a 255/35 or 275/30 if you need the extra rubber.
Originally Posted by sharkcityG
K thanks got more questions, do you think the 245 on a 9 And the 285 on 11 will look stretch?
No, those aren't stretched. You don't need or want to stretch tires on stock suspension/height.
  #3543
Old 05-25-2012, 07:46 PM
sharkcityG's Avatar
ohh i see thanks.. how low do you think i should go. or do you think the 20s will cover the wheel gap?
  #3544
Old 05-25-2012, 10:23 PM
Bunthis2's Avatar
For 20x9.5 front and 20x11 rear sitting on 235/35/20 and 275/30/20 would would be a agressive strecth look in offsets with out the wheels sticking out to much
  #3545
Old 05-25-2012, 10:37 PM
MPG35fiend's Avatar
Thanks DREW!, but remember i have AWD so i don't think 255/35/ would work?
  #3546
Old 05-25-2012, 10:41 PM
DrewDrew's Avatar
Shark-1.5" all around will close all the gap.
Bunthis- how low are you?
sharkcityG (05-25-2012)
  #3547
Old 05-26-2012, 01:29 AM
DrewDrew's Avatar
This is why I don't deal with sedans yet. I'm not familiar enough with them yet. LOL.
What's the reasoning behind this?
  #3548
Old 05-26-2012, 09:46 AM
luisp88's Avatar
im picking up a set of coupe oem 19s for my 05 sedan, the tire specs are front tires are 225/40ZR/19 and rear are 245/40ZR/19. im planning on lowering with springs. my question is which springs should i purchase without any rubbing issues?
  #3549
Old 05-26-2012, 10:28 AM
TheGThirty5's Avatar
Sup guys quick ? I have 245 35zr 20 all around, can i use 255 35zr 20 on the back, car not lowered yet thanks in advance
  #3550
Old 05-26-2012, 10:31 AM
Eibach g35 coupe springs would drop you 1.5“ all around. I had that on my sedan with 19“s and it was a perfect drop even all around no rubbing. Need a camber kit though
  #3551
Old 05-26-2012, 11:59 AM
luisp88's Avatar
did you roll your fenders?
  #3552
Old 05-26-2012, 02:52 PM
jgitt's Avatar
ok i may be in the wrong place for this question but it beats makin a new thread. Im about to order some wheel spacers and was wondering of 20mm will work with oem 19s without having to cut studs down. I dont want to have to cut wheel studs down, so hopefully someone who is using 20mm can tell me.
  #3553
Old 05-26-2012, 03:20 PM
Bunthis2's Avatar
Thumbs up
I'm on Megan racing coils
  #3554
Old 05-26-2012, 11:13 PM
oshkoshbajosh's Avatar
I have an 04 coupe without brembo's
Could I run xxr 521 18x10 all the way around or do I need to do 18x8.5 in the front.
  #3555
Old 05-27-2012, 12:05 AM
DrewDrew's Avatar
You're fine running 10 all around.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
Quick Reply: Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
