Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Aug 31, 2012 | 09:43 PM
  #4156
4DGS's Avatar
That would work too.
Old Sep 1, 2012 | 12:27 PM
  #4157
Naveed2126's Avatar
What's the best size spacers to run on a first gen sedan that is currently on all four 19x8 wheels [225/40 tires], +30mm offset wheels? Looking for a flush look.
The car is currently lowered with maybe an inch gap between tires and fenders.
Old Sep 1, 2012 | 10:25 PM
  #4158
Dcampos662's Avatar
Have tein basic coils.. Would it be a bad idea to run h&r spring with the Coilovers set up? And not use the tein springs? Dumb question but figures I'd ask tein springs are too stiff
Old Sep 3, 2012 | 02:28 PM
  #4159
luisp88's Avatar
im looking to buy some wheels for my 05 sedan. I'm lowering it on coilovers,
can someone give me ideas of what kind of offsets/dimension i should look for, I'm looking for a flush fitment, NOT looking for hellaflush fitment.
TIA
_luis
Old Sep 4, 2012 | 11:28 AM
  #4160
luisp88's Avatar
anyways....how would these specs fit on a 05 g35 sedan?
Vossen CV5 in matte graphite machined finish
(2) 20 9.0 and (2) 20 10.5.
Bolt pattern 5x114.3:
Offsets 32 F and 45 R.
Old Sep 4, 2012 | 12:43 PM
  #4161
jimmyboi860's Avatar
It'll fit but you're going to have to run some spacers to make it look good. Are you running any aftermarket suspension? Also you will need a rear fender roll.
Old Sep 4, 2012 | 01:38 PM
  #4162
4DGS's Avatar
Fenders rolled? I'd suggest just measuring how much room you have, a 20mm is what I have in mind but there are variables that will determine what size to run.
The springs aren't going to be valved correctly for the coil struts and are likely valved sitffer than the Teins.
However, Teins are notorious for being very soft. What coils are you running?
TIA
_luis
Use the search, there are tonnes of threads where everyone shows their wheel and tire specs with photos.
rear will probably rub strut...
You need a thinner wheel in the back if you don't plan to poke.
Old Sep 4, 2012 | 05:47 PM
  #4163
MPG35fiend's Avatar
Old Sep 4, 2012 | 05:48 PM
  #4164
MPG35fiend's Avatar
ok so i just found out the off set on these are +22 up front and +17 on the rear... will this work? how bad will my camber be? what size spacers should i do up front?? im thinking 10mm??
Old Sep 4, 2012 | 05:53 PM
  #4165
Drew113's Avatar
Ban Hammer Expert
what did you think the specs were?
Old Sep 4, 2012 | 06:00 PM
  #4166
MPG35fiend's Avatar
+17 front
+22 in the rear
Old Sep 4, 2012 | 06:07 PM
  #4167
MPG35fiend's Avatar
thanks!
Old Sep 4, 2012 | 06:15 PM
  #4168
josh4389's Avatar
Hello everyone,
I am in the works of building some Vs-kfs for my 06 coupe.
My off set I am thinking of are 19x9.5 +8 and 19x10.5 +4. My main concern would be what type of fender work I'll need. Also I do not want to run spacers. Any input will help. Also I forgot to mention that I have a rear camber kit and toe arm I haven't installed yet.
Thanks
Old Sep 4, 2012 | 06:23 PM
  #4169
4DGS's Avatar
What tires?
Old Sep 4, 2012 | 06:24 PM
  #4170
4DGS's Avatar
MPG, the rears are same specs as Marcus.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
